Author Topic: 550 Charging Problem Surprise  (Read 1347 times)
Offline brewsky
« on: April 13, 2013, 02:21:04 PM »
During a short ride yesterday, the engine started missing and eventually just died. Not enough juice to re-start with electric starter, but after checking fuses (OK), it fired right up with kick start.
1/2 mile later, died again. Pulled the head and tail light fuses, waited a few minutes, and kicked it again........fired right up and made it the next 5 miles home with fingers crossed.
While doing the charging system checks, the stator leads were giving some whacky readings, varying from 100 -500 ohms at the connector.
Pulled the front sprocket cover and found this!......
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Vinhead1957
Re: 550 Charging Problem Surprise
« Reply #1 on: April 13, 2013, 03:40:04 PM »
Nice to find a smoking gun!
Offline bjbuchanan
« Reply #2 on: April 21, 2013, 06:53:12 PM »
Sweet baby jesus that was beat
« Reply #3 on: April 22, 2013, 02:16:52 AM »
with a bit of luck the stator hasnt burned out from that short,you might be lucky enough to clean it up and make a resolder repair?
Offline brewsky
« Reply #4 on: April 22, 2013, 03:24:56 AM »
Fingers still crossed...........a temp crimped-in patch resulted in 14+ volts when revved up, so hopefully the alt isn't fried.
The hot wire to the starter had a bare place right where it and the alt wires went thru the grommet.
The grommet is toast and I'll bet it's NLA.
Need to pull the alt cover and do a proper sub harness replacement.
I went back thru my original pics from after I brought it home and found these, which I had forgotten:
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #5 on: April 22, 2013, 12:21:06 PM »
a petrified oil pump,looks like it was made about 3 million BC?
« Reply #6 on: April 22, 2013, 11:01:27 PM »
Er let me guess----You are in a state where they use lots of rock salt on the roads in winter?
Offline percolate
« Reply #7 on: April 22, 2013, 11:25:43 PM »
Shut the front door! Those are some funky pics.  :o
I didn't know you could use a fish for an oil pump.
Glad you made it home ok and hope you get it all sorted out without too much trouble.
The solution is painfully obvious once you know exactly what the problem is.
1976 CB550F - http://forums.sohc4.net/index.php?topic=118564.0
Offline Bodi
« Reply #8 on: April 23, 2013, 04:19:29 AM »
Sweet Mexican Mangoes! Them wires is toasted!
Not uncommon though, with the engine heat those bullets do get corroded and overheat. I've earned several cases of beer by magically fixing "unfixable" SOHC4 charging problems - just by cleaning or removing (by soldering the wires) those alternator wire bullets.
Offline brewsky
« Reply #9 on: April 23, 2013, 04:45:49 AM »
Must admit, when I first pulled the cover off I thought it might be alive!
LAMO on the petrified comment!......but sure gives new meaning to the e-bay description for "patina"
The reason I didn't dig around the grommet area to begin with is there are no connectors there and I didn't want to disturb the often stiff crunchy insulation on old wiring.........my mistake!
I did clean all the connections though.
Yes, they use plenty of salt on the roads here, but I can't figure why only the oil pump was coated, and not the rest of the exposed metal.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #10 on: April 23, 2013, 08:21:18 AM »
The reason the wires got that bad is a PO did not fit the grommet right and trapped the insulation, as to the oil pump it's first in line for all the crap
