Author Topic: choke  (Read 591 times)
Offline yorky10
choke
« on: April 14, 2013, 11:54:58 AM »
why will my 400 four only run on full choke,carbs have been sonic cleaned.yorky10
Offline captain hopeless
Re: choke
« Reply #1 on: April 14, 2013, 12:24:25 PM »
Are the carbs set to stock settings? (i.e. air screws, floats, needles, jets, etc). More specific details and symptoms might help with diagnosis.
It's probably running lean somehow. Alternatively if it won't even idle then maybe the idle screw is not set properly, requiring engagement of the fast-idle cam on the choke lever?
Offline Schnell
Re: choke
« Reply #2 on: April 14, 2013, 01:54:26 PM »
Stock airbox or pods?
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline yorky10
Re: choke
« Reply #3 on: April 15, 2013, 01:24:54 PM »
as far as I can tell its as it left factory,its not been used for 20 years,so I had the carbs done by a pro,ihave checked timing tappets,float height,is it fuel starvation?yorky10
Offline iron_worker
Re: choke
« Reply #4 on: April 15, 2013, 02:27:31 PM »
Did he properly rebuild them by dissassembling or did he just dip the whole carb in an ultrasonic cleaner and call it good?
Sounds like you either have a massive vacuum leak or your pilot jets are completely plugged up.
IW
Offline bjbuchanan
Re: choke
« Reply #5 on: April 15, 2013, 06:05:52 PM »
With carbs there is usually a short list of "pros" that do the job correctly, especially on motorcycles. They get by with cars because the passages are usually considerably larger, comparably atleast. The bikes get clogged up bad and easy too
