Author Topic: My new chopper. A real "back in the day" survivor.  (Read 100919 times)
0 Members and 11 Guests are viewing this topic.
Offline jaguar
Re: My new chopper. A real "back in the day" survivor.
« Reply #100 on: July 09, 2013, 06:42:22 PM »
Cbx might be on its way to WA state, and then I think Japan after that.
Im just not going to do right by it.
« Reply #101 on: July 09, 2013, 07:00:15 PM »
It should go to Bullhead City.
Offline jaguar
« Reply #102 on: July 09, 2013, 07:20:49 PM »
Bullhead?
« Reply #103 on: July 09, 2013, 08:07:10 PM »
« Reply #104 on: July 09, 2013, 09:06:05 PM »
I like them orange stacks..
Offline jaguar
« Reply #105 on: August 12, 2013, 01:20:34 PM »
Dug up some charging parts.
Figured I would swap on in and "band-aid" the system for the rest of the season.
Over the winter ill build a proper harness and swap in a solid state rec/reg
Made a tail light bracket.
Nothing special, just some thing simple.
Also got an oil cooler adaptor.  It's for a 750, but I think it should be the same for the 550.
Need to find an actual cooler.
« Reply #106 on: August 12, 2013, 04:08:21 PM »
Did you buy those carbs?
Offline jaguar
« Reply #107 on: August 12, 2013, 06:35:54 PM »
I did buy a parts carb rack to repair mine.
Offline SOHC Digger
  • I'm not an
« Reply #108 on: August 13, 2013, 05:16:45 AM »
License plate bracket looks good.  Doesn't have to be anything special.  I can't see spending the prices some of these places are asking for their brackets.  Well done!
Offline jaguar
« Reply #109 on: August 13, 2013, 07:13:24 AM »
That's kind of where I was coming from.
And I figured with the overall patina of the bike a new modern bracket with fresh Powdercoating would look funny.  Goal was mostly to slim down the mount that was on the bike now.
Just used some scrap steel I had in the garage.  Did buy the mount part from speedy, made the whole thing easier and cleaner.
I know it's cliche but I like the model A light.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #110 on: August 13, 2013, 09:11:03 AM »
Are you thinking of running 750 carbs?  Even with a BIG bore kit, they still may be too big at 28mm, unless you do a whole lot of head work.
Offline jaguar
« Reply #111 on: August 13, 2013, 11:59:12 AM »
No, not running the CB750 carbs any time soon.
Was more a comment on having a ton of 750 parts around and not having the 550 part I needed.
Maybe if I ever "build up" a moto for this ill think about it.
For now stock is just fine.  This bike is small and light.
Offline jaguar
« Reply #112 on: August 13, 2013, 12:00:06 PM »
Trying to decide what pipes to order.
Longer or shorter?
Offline jaguar
« Reply #114 on: August 13, 2013, 03:26:50 PM »
Have seen those.
Kinda like the slight up kick of the cycle x pipes, but need to see if they will make then in 550 diamiter
« Reply #115 on: August 13, 2013, 03:29:03 PM »
How about some pipes that run up the line of your sissy bar and end with a fishtail?  It's a choppa, baby!
Offline jaguar
« Reply #116 on: August 13, 2013, 04:07:11 PM »
I want to keep the pipes low.
Had thought a out fishtails though, not sure about it yet.
Offline toytuff
  • "watching the pinheads"
« Reply #117 on: August 13, 2013, 04:52:14 PM »
Long pipes all the way!
tt
Offline jaguar
« Reply #118 on: August 14, 2013, 04:00:41 PM »
Kind of wish they had one size in between.
Think the difference is nine inches, half that might be perfect.
Offline SOHC Digger
  • I'm not an
« Reply #119 on: August 14, 2013, 10:43:37 PM »
Go with the shorts.  They look like they would follow the frame better.
No fishtails please ;)
Offline jaguar
« Reply #120 on: August 15, 2013, 04:32:24 AM »
I want them to kick right after the rear brake controls.
Agree that fishtails wouldn't fit this bike, maybe a simple angle cut
Offline Sparked
  • Cheaper then therapy
« Reply #121 on: August 15, 2013, 07:04:00 AM »
If your going to ask CycleX if they can make some custom diameter, might as well as if they can do a custom length too. I like the up kick of those pipes.
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline jaguar
« Reply #122 on: August 15, 2013, 09:26:43 AM »
Good point
Offline Syscrush
  • Sold. :(
« Reply #123 on: August 15, 2013, 01:56:32 PM »
It's a cliche for a reason - they're cool and lots of people like 'em!
Very exciting, I love to see unrestored survivors like this.  Keep up the good work.
Offline jamesb
« Reply #124 on: August 15, 2013, 01:58:49 PM »
If you go with longer pipes make sure your brake pedal and shifter don't interfere with them. I have had that problem before with some of my choppers and I'm currently going through it now with one.
