With the valves...unless you are way off...you won't see much difference in
the bikes running, and unlike the carb tuning, you won't see an immediate
difference. You will see a difference on adjusting the timing if you do it with
a timing light rather than statically. But all these adjustments...and the point
gap...will affect the carb balance, which is why you want to do it last...or do
it several times.
Should clarify....by see a difference...I mean an immediate difference as the bike
will be running.
Jim
