Author Topic: tune-up order  (Read 2353 times)
brad
tune-up order
« on: July 25, 2006, 09:11:44 PM »
so i've changed the oil and the plugs.  what next?
i planned on doing these in this order.  is this wrong? does it matter?
1) carb sync
2) valve adjustment
3) timing
Offline techy5025
  • 1969 Diecast and Sandcast 750's
Re: tune-up order
« Reply #1 on: July 25, 2006, 09:19:49 PM »
...do the carb sync last.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline scunny
  • don't call me expert
Re: tune-up order
« Reply #2 on: July 25, 2006, 09:21:55 PM »
I'm with Techy; valves, timing then carbs
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline techy5025
Re: tune-up order
« Reply #3 on: July 25, 2006, 09:40:44 PM »
With the valves...unless you are way off...you won't see much difference in
the bikes running, and unlike the carb tuning, you won't see an immediate
difference.  You will see a difference on adjusting the timing if you do it with
a timing light rather than statically. But all these adjustments...and the point
gap...will affect the carb balance, which is why you want to do it last...or do
it several times.  ;D
Should clarify....by see a difference...I mean an immediate difference as the bike
will be running.
Jim
2003 CBR600F4I
Re: tune-up order
« Reply #4 on: July 25, 2006, 11:27:59 PM »
Carb sync makes the engine hot.  Valve clearances are adjusted cold.
Tuneup process - cold engine:
Pull spark plugs.
Set valve tappets
Adjust cam chain tension.
Compression check (cold)  Compare with previous numbers, (I know, best numbers are when engine hot)
Dress points - Set point gap, and static time.
Replace or clean/gap plugs; install with anti-sieze
Replace or clean air filter.
Clean oil breather element foam.
Start/ warm engine with fan blowing on it.
Stop engine install vacuum gauges.
restart check/adjust vacuum sync.
Tweak Idle screws as necessary.
Change oil/filter.
Grease swing arm fittings.
Check tire pressures.
Check/adjust drive chain tension.
Check for loose spokes.
Check battery fluid levels.
Test ride
TEST ride
test RIDE
TEST RIDE
When done for the day, lube drive chain
Offline puppytrax
Re: tune-up order
« Reply #5 on: July 26, 2006, 06:30:48 AM »
...???...Is that CB750-specific??? I don't recall an oil breather element on my CB500/550...   :(
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline byidesign
Re: tune-up order
« Reply #6 on: July 26, 2006, 07:15:33 AM »
Always carbs last after all else is perfect,
    Then Enjoy
            Bruce
82CB650SC,80CM400
Offline jph550
Re: tune-up order
« Reply #7 on: July 26, 2006, 07:29:40 AM »
depending which 550 you have (I don't think there's one on a 500), there is a tube running from the valve cover which circulates unburnt gasoline back through your air filter and into the carbs. It has to pass through a foam filter element at the bottom of your stock air breather box.  at least that's all I could imagine it being.  cleans with sudsy water and ATF fluid. see manual
'76 cb550K
with original faded brown/green tank
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: tune-up order
« Reply #8 on: July 26, 2006, 07:34:27 AM »
We (UK) had it from the 550K3 on. Never appeared on the 500.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline puppytrax
Re: tune-up order
« Reply #9 on: July 26, 2006, 07:38:57 AM »
...Unburnt gasoline in my valve cover??...   :o
OK, all kidding aside...   ;D  (I'm guessing it's a rudimentary PCV vent)...
I know what you're referring to now...my 500 hose just exits to atmosphere near the swingarm pivot; but the two 550's had AC boxes with an extra chamber on the bottom, with a spigot for the hose...there were no elements, but I know what they look like, from old Chevy air cleaners of the 60's and 70's...   ;)
Might be something to change over to in the future, as I have the AC boxes...seems to me I  recall someone saying the 550 AC element itself was different, too...
« Last Edit: July 26, 2006, 07:41:04 AM by puppytrax »
    • TVAM
Re: tune-up order
« Reply #10 on: July 26, 2006, 07:46:46 AM »
The 550 air cleaner element is different - because the box is a different shape to accommodate all the environmental gubbins.
I say ditch it all and go back to the way it was when these bikes were first designed!
SOHC4 Member #2393
Offline puppytrax
Re: tune-up order
« Reply #11 on: July 26, 2006, 08:02:20 AM »
I would tend to agree...but...when removing one of my 550 motors from the frame, I noticed there seemed to be a sand plug in the valve cover breather spigot [no hose on it]...turned out to be a larvae for a sand wasp...   >:(
It's bad enough that I seem to have an inexhaustible supply of field mice in my storage shed; I don't need sand wasps plugging up all my open holes...on the bikes, I mean...   ::)
Re: tune-up order
« Reply #12 on: July 26, 2006, 10:09:54 AM »
Chapter eight of the cb500 550 shop manual lists the recirculating breather as a new feature of the Cb550 models.
I believe all the Cb400s have a similar arrangement.
I'm not sure when the Cb750's got the recirculating breather, certainly by 77.
I hope you are joking.  The crankcase vents oil vapors and blowby gasses (Carcinogens) past the piston rings into the atmosphere and lungs of nearby mammals.  You'd really prefer to breathe these fumes rather than simply having the engine incinerate them?
The recirculating breather costs no horse power and simply adds one extra hose and a foam element water separator.  It's very hard to believe this is too complex a system to deal with.
