Author Topic: Yes, a Z1 & H1- unofficial Kawasaki thread - H2 is now a rider!!!  (Read 244027 times)
Offline toytuff
  • "watching the pinheads"
Re: Yes....I got a Z1
« Reply #150 on: May 13, 2013, 05:16:15 PM »
Yeah, good point Terry.  As I've stated earlier this will be going back to stock.  I have no plans to sell but you never know, and I'd like to at least get my investment back if I did have to sell. So now, waiting on parts...
Know all about waiting on parts. Four weeks now on the carburetor.  ::) You know me. Keep it as stock as possible.
tt
« Reply #151 on: May 13, 2013, 05:30:04 PM »
tt
New carb or rebuild?   I just changed all the orings in the petcock and still leaks a drip damn it!
Didn't you have same issue?
Offline toytuff
« Reply #152 on: May 13, 2013, 06:28:15 PM »
tt
Rebuild. New carburetors are rare as hens teeth.
Not yet. Still no gas in tank. No carburetor.
tt
« Reply #153 on: May 16, 2013, 06:55:09 PM »
So when working on my petcock, I noticed it has two nipples but one of them capped off.
Looked at the fiche and it looks stock. Checked my carbs and do not see where another fuel line could be hooked up so am now thinking I do not have stock carbs.
They kinda look like smooth bores but don't have the square cast box on #4 or large drain plug underneath that I was told about on the KZ Rider forum.
You recognize these? I know MIC is Mikuni...
And heres a link to Z1 carb ID....
http://www.z1enterprises.com/Z1CarbGuide.aspx
« Reply #154 on: May 16, 2013, 07:10:07 PM »
Steve-O, do they have accelerator pump?  Even, if you don't see one, they could be VM29 pumper carbs(not smoothbore).  Guys often plugged off the pump circuit and swapped float bowls.  These carbs are stock for the 78 and later bikes but bolt right on to any z900/1000...
« Reply #155 on: May 16, 2013, 07:38:58 PM »
Yes, on the number 2 carb. I'm thinking they are for a later model Kaw
« Reply #156 on: May 17, 2013, 11:21:21 PM »
they are generally considered second only to smoothbores...as far as factory performance carbs from the era...correct carbs appear to be vm28's or vm26's as per your link   ...some po was upgrading
« Reply #157 on: May 18, 2013, 01:56:32 AM »
Did you clean the varnish off the exterior of the carbs to see if the seals are weeping a little? Looks like the one is weeping or has weeped a bit at some point. Mikunis are very good quality carburators.
I think Scottly has Mikunis on his Seeley and knows how to tune them properly if yours need any work. There is a thread about tuning either Mikunis or Weber carbs.
It is funny how Delatoro?spellin? And Weber and few others have similar carbs and camps of followers who claim superior performance of their version of very similar design in the car world.  When I first got my '66 Volvo 122S Amazon it had a Weber DGV downdraft carb instead of the stock twin SU carbs. While it performed OK it was jetted wrong and was known to perform poorly at higher speeds. It simply could not flow the air needed by the engine. I rebuilt the old worn SU HS6 carbs and rejetted them with SU carbs and put a 2" free flowing exhaust on the car and it transformed the car. Dropping a camshaft with a little more lift and duration woke up the power as well. Fun car and loved the sound of the twin SU carbs.
« Reply #158 on: May 18, 2013, 06:51:59 AM »
I think that is the case, possibly upgraded at some point. The bike was shown some love back in the day, custom paint and chrome bits are evidence of that. I believe the vm28's were stock for mine and in '76 the KZ900 had the vm26's.
No, have not cleaned them yet, maybe today, and may have to rejet when I install the original style 4 into 4, plan to order next month.
« Reply #159 on: May 18, 2013, 07:54:15 PM »
They're not smoothies Steve (float bowls are wrong) they're probably 28 mm Mikuni's off a Suzuki GS1000. From memory Kawasaki dropped the 28's after around 1974, and they went down to 26mm carbs for a little more torque, so the "fix" was to strap on a set of Suzy carbs. That's my guess, anyway. Cheers, Terry. ;D
« Reply #160 on: May 19, 2013, 01:41:38 PM »
Received some parts this week, a really nice powdered coated triple and side stand and some repop gauge covers...
Removed the old triple and guages and installed the new ones with all new hardware for the bar clamps and triple.
Also changed the upper [too long] brake line and flushed out all the old nasty fluid.
Front brake feels great, rear is so so and new shoes are on the list.
PO must have had some ape hangers on there as clutch cable is too long too, will order a new one.
The repop covers may not look good in the pic, but the paint work is very nice. All of Z1's parts are made in Japan.
Bolted on the powdercoated side stand, was happy to get rid on the chrome plated one. Didn't realize the chrome one was shorter than stock, prolly installed when the 16" rear wheel was installed. Looking for a centerstand replacement too.
Took it out for an 18 mile test ride, running great.
Next up:
Just ordered a new rear Avon tire and tube and need to order ss spokes for the new 18" DID rim I have on the shelf.
« Reply #161 on: May 19, 2013, 03:31:42 PM »
And looking great.. ;D   What are you doing about pipes..? Not that that one is ugly or anything {cough bullsh1t cough bullsh1t}   8)
« Reply #162 on: May 19, 2013, 03:57:58 PM »
Don't sugar coat it Mick! They are ugly, no question. I'll be ordering original style four into four next month. They are a little pricey at $1400, but worth it in my book.
« Reply #164 on: May 19, 2013, 04:00:51 PM »
That bike will look very nice with the 18 rear and stock pipes, very tidy... You going to go for stock paint eventually..?
« Reply #165 on: May 19, 2013, 04:05:49 PM »
« Reply #166 on: May 19, 2013, 04:15:54 PM »
Yes, will be getting stock '75 paint eventually but low on the list.  Rear wheel/tire/brake is next, then pull ugly pipes, address a couple minor oil leaks [gaskets?], tidy up motor and replace a couple engine covers, one is damaged and one not stock.
And want to get the oil pan trap door installed that Jon suggested as the oil light came on again today when I launched it!
Offline toytuff
« Reply #167 on: June 01, 2013, 01:19:33 PM »
Hmmm..
Sold off most of the not needed anymore toys with 15K in cash stuffed in a bank bag.
Kind of like this one but a little high yet.
http://mohave.craigslist.org/mcy/3840830856.html
Got me looking at some kawie stuff now Steve!  ;)
tt
« Reply #168 on: June 01, 2013, 03:18:08 PM »
That looks nice Toy, but would much rather have this...
http://motorcycles.yakaz.com/kawasaki-z1-for-sale#lo=4&docid=000emmgb2k56h972
Offline toytuff
« Reply #169 on: June 01, 2013, 04:32:51 PM »
No price.
tt
« Reply #170 on: June 01, 2013, 04:40:01 PM »
Offline toytuff
« Reply #171 on: June 01, 2013, 04:41:49 PM »
Offline toytuff
« Reply #172 on: June 01, 2013, 04:50:47 PM »
E-mail sent.
tt
Offline toytuff
« Reply #174 on: June 01, 2013, 05:51:00 PM »
No, not on the internet! I read on the internet that won't happen.
tt
