Author Topic: Yes, a Z1 & H1- unofficial Kawasaki thread - H2 is now a rider!!!  (Read 254374 times)
Re: Yes....I got a Z1 and now an H1! Motor rebuild in progress...
« Reply #1025 on: April 05, 2015, 05:02:54 AM »
Glad you're getting the parts you need. It bites when the weakness of the old relics of our youth we like or enjoy start showing their design weakness and we have to experience it first hand. I have the worn rocker shaft issues on my 550 and trying to find a good head that is affordable is a pain. Especially when you don't have the cash lying about to finance it...
« Reply #1026 on: April 11, 2015, 10:35:40 AM »
Got my NOS head gasket for the H1, it's copper BTW.  Guys on the Triple forum are suggesting to use a light coat of copper spray on it. Also sourced some [used] Mikuni jets and needles, next to impossible to find new and from what I am told, the aftermarket parts are garbage. Sound familiar?
In the mean time, I've done a couple small things to keep this project moving. Replaced the rear cowling with the new bodywork set on bought on ebay awhile back. The old metal cowling was very rusted on the inside, worst part on the bike.
There are four bolts holding this on and I broke 2 off trying to loosen em. Luckily I was able to extract them fairly easy. New [used] taillight assembly too, the wiring was hacked on the old one and the brake light didn't work.
I've had very good luck getting parts for reasonable prices for this bike.
Look closely at the shine on the new part, see a bike in the reflection?
The front brake was working but did hang up a little.  Pulled it off and used the "grease gun" method to remove the piston.
Piston cleaned up fine and the inside of the caliper as well.  Prepped the body, a couple coats of caliper paint and a new seal and we're as good as new.
It's a 3 part assembly...
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #1027 on: April 11, 2015, 11:10:36 AM »
Great stuff Steve-o!
I have a motorcycle problem.
Offline toytuff
  • "watching the pinheads"
« Reply #1028 on: April 17, 2015, 07:22:05 AM »
Onward!
 :P
tt
« Reply #1029 on: April 17, 2015, 12:22:42 PM »
Cool !
« Reply #1030 on: April 18, 2015, 02:00:45 PM »
Ok, I'm back at it.  At the suggestion of one of the guys on the Triples forum, I thought I would check the head to be sure the mating surface is flat.
The wife has a nice marble table on the back patio, thought it would be perfect for head decking! Had some 320 grit wet/dry...
Here it is after a few min...
And after a few more. Changed paper too...
The little mark on the right side of the chamber cannot be felt with my finger, so think it is a non-issue.
Offline NobleHops
« Reply #1031 on: April 18, 2015, 05:02:40 PM »
So, given the look of the head in the first photo, the head was slightly less than flat, eh?
What's your takeaway Steve-o, would you do this as a matter of good practice in the future? (Asked the guy with the H2...)
« Reply #1032 on: April 19, 2015, 08:40:57 AM »
Stev-o,
Make sure to do all 3 heads equally so you keep even compression numbers between the cylinders..
« Reply #1033 on: April 19, 2015, 09:21:37 AM »
Yes, it did appear not to be perfectly flat.  I do think this should be included in any motor rebuild and will be doing it on the next.
Stev-o a good trick to determine if it's flat is to paint the bottom with machinists marker.
Although I did not get a pic of it, I did use a magic marker on the head.  Not as good as a machinist marker but it did the trick.
Not a bad idea but I doubt I removed enough aluminum to increase numbers?
« Reply #1034 on: April 20, 2015, 03:48:31 AM »
Stev-o,
All 3 heads - sounds like a dragon from a fairy tale.  ;D ;D
« Reply #1035 on: April 20, 2015, 05:01:21 AM »
That could look really sweet air-brushed on the side panels of his H1!
  Maybe even as a big tatoo on his chest or his burly upper arm area !!
« Reply #1036 on: April 20, 2015, 05:06:50 AM »
Or a back piece? I like the image: "Where's there's smoke, there's fire!" Nice association for a 2-stroke fire breather of an engine. Great find Prokop!
we just want all 3 w/ the same amount of Fire  ;D
« Reply #1037 on: April 20, 2015, 05:07:33 AM »
  Think I read in another thread that Steve already has a Tramp Stamp.  Found it   ;)
« Last Edit: April 20, 2015, 05:15:13 AM by ekpent »
« Reply #1038 on: April 20, 2015, 05:34:04 AM »
Ah, no tats here, I think that Uncle Terry in that bikini!
« Reply #1039 on: April 23, 2015, 06:17:10 AM »
Is Uncle Terry even tuned into this thread for you to get a rise outta him ;-) ???
What makes you think the marble table is flat?
(Which one is the wicked evil grin?) :-D
« Reply #1040 on: May 09, 2015, 07:27:28 AM »
Plan to retorque the heads today and do a test ride if the roads dry put and rain stays away.
Been raining nearly every day this week, no seat time at all.
Here's a pretty cool video if you have six min to spare.  It's a track test at Fontana of the new and old H2.
The '72 H2 is owned by a member of the Triples forum, but he is not the rider. Enjoy...
« Reply #1041 on: May 09, 2015, 12:51:18 PM »
They're really 'letting the Good Times Roll' w/ this new one;I didn't see enough of the older H2 in that video  :( .I hope you do a video of your bike when you get'er good Stev-o.  :)
Offline Godffery
  • Godffery's Garage
« Reply #1042 on: May 09, 2015, 04:55:22 PM »
   Stev-o,
I may have a set of Phenolic Brake Caliper Pistons to fit your H2.  While working on a set myself, I noticed they bear a striking resemblance to the DOHC 750 Caolipe Pistons : http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/PHENOLIC+Replacement+brake+Caliper+piston/PHENOLIC+Replacement+brake+piston+for+Honda+CB+650+-+750+DOHC/ and they measure only 1mm taler then the KH.
LMK if your interested.
   G~
« Reply #1043 on: May 09, 2015, 07:19:04 PM »
   Stev-o,
   G~
Have not received the H2 yet, so not sure what size they are.  But thanks.
Offline Godffery
  • Godffery's Garage
« Reply #1044 on: May 09, 2015, 08:09:09 PM »
They look like the one you posted a pic of.  Perhaps I'm confusing the H2 with the H1 calipers?
« Reply #1045 on: May 10, 2015, 06:36:49 AM »
Yes, the pics posted were of my H1 500.  That piston cleaned up well and brakes working well, although a little spongey.
The H2 I bought is in MN awaiting pickup from the shipper. You still have that Z1 roller?
« Reply #1046 on: May 10, 2015, 07:34:10 AM »
Did you get her out yesterday?
« Reply #1047 on: May 10, 2015, 08:05:59 AM »
Yes, rolled the H1 out after torquing the heads yesterday, started up within 10 kicks or so (I think it's been two weeks since last run).  Sounded good so I suited up.  The bogging out is first gear is a little better, bike really screams above 4K RPM.  But trying not to push it too hard since I'm still under 100 miles since rebuild.
After about 10 miles, it starts bogging bad, I pull over and it dies.  I checked fuel level before I left and it appeared to have at least a gallon, thought that would be plenty.....wrong.  Flip the petcock to reserve and it kicks back to life, off to nearest fuel station, about 3 miles away.
Fill it up with 93 octane, then does not want to start, WTF?
Decided to try to push start it, and I am off and running again.  The sky was looking pretty dark and not wanting to get stranded and soaked, I head back to the house.  Once back in the driveway, I shut it down and kick start it, fires right back up.   The non-start at the gas station frustrates me but I have not put the genuine Mikuni brass in the carbs yes, that is the plan for this week.
I feel progress but albeit slow, but like I stated earlier, was taking a step back.
« Reply #1048 on: May 10, 2015, 08:29:26 AM »
Nice!
I suppose it has oil pump or do you mix in the gas?
I would love to try out different 2 stroke than CZs and Jawas i messed with in previous life.  The power flwxibility of two strokes was always amazing.
Offline Godffery
  • Godffery's Garage
« Reply #1049 on: May 10, 2015, 09:36:42 AM »
Ok groovy.
I sold the Z1 roller to a neighbor last fall.  Sorry.
