Author Topic: Mikuni flat slides ,  (Read 2898 times)
Offline Red Good
« on: April 16, 2013, 08:21:07 PM »
found a set rooting through a box today . Anyone familiar with the numbers on them 27A10 ? only other # is Q5 5 4
Anf info is helpful . Set of four on a rail . 1-2 and 3-4 look spaced right for sohc but the 3-4 spaceing is off a bit . help any ? I will try to get some pics up soon .
Re: Mikuni flat slides ,
« Reply #1 on: April 16, 2013, 10:06:12 PM »
Pics..?   you mean 2-3 spacing is off..?
Offline Red Good
« Reply #2 on: April 16, 2013, 10:30:45 PM »
No idea where they came from or what they should fit , but they are a little wide in  the 2-3 spacing  for an sohc . 1-2  and 3-4 alignment look good , just a little wide in the middle . Will get pics up tommorow . Kinda look like Mikuni RS , we shall see .
« Reply #3 on: April 16, 2013, 10:37:42 PM »
If they are a little wider in the middle they are probably spaced for the Z900-1000 Kawasaki's and GS suzuki's, if they are you can run them on a Honda, i can't remember who makes them but you can get manifolds to run the Kawasaki spaced Mikuni's on our bikes, i have a set....
Offline turboguzzi
« Reply #4 on: April 17, 2013, 01:50:03 AM »
pictures would help but sounds like early GSXR750, 85-87, the so called VM29SS, in reality more like TM. not a bad carb
« Reply #5 on: April 17, 2013, 02:39:44 AM »
The early gixxer carbs were a bit on and off...  Wouldn't they be smaller spacing than the CB..?
Offline turboguzzi
« Reply #6 on: April 17, 2013, 05:11:12 AM »
spacing could be as red good describes, hard to understand without measurements or pics
back at the time i managed to sort them pretty good on my 750gixxer, but sure, not exactly made for two up touring :)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #7 on: April 17, 2013, 04:42:34 PM »
redgoo, the sudco boots should maybe work for you.  i might have a spare set if you dont!
Offline Red Good
« Reply #8 on: April 17, 2013, 07:17:27 PM »
Pics here
http://s256.photobucket.com/user/superdak/media/IMG_1140_zps2eec7e7b.jpg.html?sort=3&o=2
Medyo , got those special boots for the 29's , i am thinking these will work if i saw it all in half and move the 2-3 closer together .
« Last Edit: April 17, 2013, 07:21:28 PM by Red Good »
« Reply #9 on: April 17, 2013, 08:42:32 PM »
Sudco, thats the ones....  Here's your carbs mate..  Like i said earlier, if they are GS or Z spaced and it looks like they could be, then with the Sudco manifolds they will bolt right up. I have a set of Yoshi set up CR31's, they are CR900's and are still in the Kawasaki / Suzuki spacing, they currently reside on a 750/4 in my shed....
« Last Edit: April 17, 2013, 08:45:21 PM by Retro Rocket »
Offline turboguzzi
« Reply #10 on: April 18, 2013, 05:03:37 AM »
yep, I sniffed right :) early gsxr VM29ss, 77-90-77 mm  spacing, sir. Red, if you are in the USA, then they are  quite a rarity, 1st series gsxr were sold with CVs or they or off a rare LTD.
Never had a CB750, no idea how they'd fit but honestly, custom inlets stubs are not that hard to do.
if they are in good shape would give them a try tough the quick aluminum filler hints that they need fixing?
Offline Red Good
« Reply #11 on: April 18, 2013, 10:00:13 PM »
That's cool guys I think they will find a home on an 836 motor I have .
The quick aluminum filler is to repair a broken float post . The po was kind enough to leave it in the bottom of the bowl .
Anyone have an idea what they should be jetted at for a Wiseco  836 with a cam and mild headwork ?
Thanks guys appreciate the info  .
Offline ji107
« Reply #12 on: April 18, 2013, 10:36:57 PM »
You may want to try welding the post as shown on this forum further down under in the classified  in the services offered, " float posts repaired with micro laser welding"
J I
« Reply #13 on: April 18, 2013, 10:42:33 PM »
J I
+ 1, i've seen Jims work and it is excellent...
Offline Jim F
  • go baby go
« Reply #14 on: April 19, 2013, 11:40:40 AM »
J I
Thank you sir
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #15 on: April 19, 2013, 04:25:11 PM »
J I
Thank you sir
Jim
My pleasure Jim, its you skilled and talented people that make this place such a great resource..  ;)
