Author Topic: Idle speed more than doubles once bike is warmed up  (Read 643 times)
Offline Scott
  • 72 CB750
« on: April 18, 2013, 09:54:12 PM »
Hello there
I have a CB750 K2.
I've done a bit of work on the bike such as carby kits including new jets and needle and double checked the float height.(I did move the clip on the needle down one notch)
New carby rubbers and clamps, new K&N air filter and air box rubber seal.
New throttle cables.
The bike starts up fine from cold and idles at about 900 to 1000 RPM ( going off the bikes tacho).  Then after about 5 to 10 minutes riding the idle goes up to over 2000 RPM
Any sugestions or thoughts at all will be appreciated
Scott
Online bryanj
Re: Idle speed more than doubles once bike is warmed up
« Reply #1 on: April 18, 2013, 11:15:49 PM »
You have the tickover set too kigh, set it to about 1100 when hot and hold the throttle open a touch when cold
« Reply #2 on: April 18, 2013, 11:36:54 PM »
float valve not working properly and/or vacuum leak.
Offline Scott
  • 72 CB750
« Reply #3 on: April 18, 2013, 11:44:55 PM »
cool thanks and thanks
I'll go do that now and check for leaks just incase
Have a good one
Scott
Offline Scott
  • 72 CB750
« Reply #4 on: April 19, 2013, 03:33:57 AM »
Thanks mate all good
