Wire is measured in impedance by gauge and length. If you know both, you can look it up easily enough. It's not the impedance that is playing the role. It's an RF choke, absorbing the noise. A cap in that range should work well, is very cheap, small, and easy to hide in the wiring. Doubling those little ceramics won't give you enough effect. 500 of them will, though. As I said, advice from someone not on the bench for 20 years. Cheap advice but at least it's a cheap part to try!
