Author Topic: Generator leak.  (Read 1271 times)
Offline klaus.s78
Generator leak.
« on: April 22, 2013, 10:01:59 AM »
Hi. i have a cb750 1976 F, and where the wires comes out from the generator, oil is running out, how do i seal it.
Thank you.
Klaus
Offline phil71
Re: Generator leak.
« Reply #1 on: April 22, 2013, 10:23:49 AM »
can't answer that until you pull it apart.
It can be anything from a gasket to a cracked part. Some fixes are easy, some less so. get it apart and report back.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Generator leak.
« Reply #2 on: April 22, 2013, 10:32:32 AM »
Best advice.
It could also be the grommet that the wires feed out. It may be unseated or just warn to the point where some oil will sneak by. Again you will have to pull off the cover to check it.
Offline klaus.s78
Re: Generator leak.
« Reply #3 on: April 22, 2013, 10:38:21 AM »
Okay will do it tomorrow.
The gasket i new, i think it is the grommet but will check tomorrow.
If the grommet is worn , do you think i can seal it with liquid gasket?
Klaus
Offline Bob Wessner
  • "Carbs Suck!"
Re: Generator leak.
« Reply #4 on: April 22, 2013, 11:03:09 AM »
Perhaps. You might be better off just replacing it if that turns out the culprit. How much of a leak do you have?
Offline crazypj
  • I'm brill, me
Re: Generator leak.
« Reply #5 on: April 22, 2013, 11:08:38 AM »
If grommet is worn or damaged I don't think you have too many options other than liquid gasket
Isn't it molded around the wires?
Offline Bob Wessner
  • "Carbs Suck!"
Re: Generator leak.
« Reply #6 on: April 22, 2013, 11:30:18 AM »
Crazy, it appears you are correct. Checking the parts list and illustrations suggest this is all part of one major unit. The grommet is not listed as a separate part. Looks like the wiring is fed through it during manufacture/assembly.
bollingball
Re: Generator leak.
« Reply #7 on: April 22, 2013, 11:52:26 AM »
That grommet has never been available. Clean it good with some brake clean to get all the oil off best to remove it to get to the back side and work in some epoxy or you will need to buy the whole thing.
Ken
Offline phil71
Re: Generator leak.
« Reply #8 on: April 22, 2013, 12:06:39 PM »
in my experience, alternator case isn't under pressure, and whatever oil gets as high as the grommet is just a mild splash, so even when it's kinda dogged, it's not usually the culprit . if it's a real leak that drips even when the bike is off, it's going to be a lower part of the gasket or a crack.
Offline crazypj
  • I'm brill, me
Re: Generator leak.
« Reply #9 on: April 22, 2013, 02:33:17 PM »
It probably got displaced when new gasket was fitted so may now be damaged?
Offline klaus.s78
Re: Generator leak.
« Reply #10 on: April 23, 2013, 06:11:16 AM »
It was the grommet, i´ll clean it and use some liquid gasket. There was alot of oil :-/
Thank you all for your help....
Klaus
Offline bluesoverlord
Re: Generator leak.
« Reply #11 on: April 23, 2013, 07:01:29 AM »
Of all the parts that are fabricated by various businesses as well as the peeps around here this is one of them that I can't understand why someone with fabrication skills hasn't taken on. The only thing I can think of is that it would be a low cost (e.g. profit) item. The other one is the rubber piece that the chain rides on by the drive sprocket. Not made anymore. But, when your only option is to buy a whole stator just because of a grommet, well that just plane sucks....and is a problem waiting to be solved.
Hondaman?
Offline klaus.s78
Re: Generator leak.
« Reply #12 on: April 23, 2013, 08:21:07 AM »
I agree, I think you´re right, it´s all about the money :-/
