Author Topic: Best engine mods  (Read 5501 times)
Offline nitrofish1
Best engine mods
« on: April 23, 2013, 09:14:25 AM »
Lets say that I've changed my mind, once again, sort of, about how much to spend on modifying my 750's engine.
If I spend 1200 or so, not including the cost of gaskets, what would be the best way to extract power out of that engine? A mild port, big bore with upped compression, new valve train combo?
Or should I just purchase the APE 836 kit which includes all of this except the head porting? Also mind that with a bigger bore comes the cost of boring and new sleeves.
Offline nitrofish1
Re: Best engine mods
« Reply #1 on: April 23, 2013, 09:24:01 AM »
I'm probably only going to have this bike's motor apart once, unless something breaks, and it is going to be my cafe racer, so I'd may as well make it perform. I don't think it will be my last cafe bike but for a bike that I'm building to represent myself, I'd just like it to be fast.
Offline Schnell
« Reply #2 on: April 23, 2013, 10:08:51 AM »
Add nitro?
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #3 on: April 23, 2013, 10:33:18 AM »
or fish? ;D
Offline nitrofish1
« Reply #4 on: April 23, 2013, 10:44:22 AM »
HA! so really what is the best?  ::)
« Reply #5 on: April 23, 2013, 10:47:23 AM »
The best way  is to buy Mark Paris's book:
http://www.lulu.com/us/en/shop/mark-paris/my-cb750-book-hardcover-edition/hardcover/product-16107855.html
He talks about cheap and not so cheap alternations to the motor for power gains - besides a wealth of information on maintenance and technical details.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=sicklheos6ibnbii4r12a4hdb3&/topic,60973.0.html
« Reply #6 on: April 23, 2013, 10:48:09 AM »
why not just run it..as it is,,, for 1 seson
i hate all this v-w.... vords
Offline nitrofish1
« Reply #7 on: April 23, 2013, 10:53:21 AM »
Book is a bit pricey......  :o
Is there a sport to be had in running it stock? I was just considering a hotter cam and valve springs upgrade but I was thinking of going a little further, hence the question on post 1.
« Reply #8 on: April 23, 2013, 10:54:57 AM »
I think you should contact MReick. He dies head work and has a motor he built for himself puts out close to 100 Hp
Offline setdog
« Reply #9 on: April 23, 2013, 10:56:15 AM »
Buy another motorcycle...best mod ever!!
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline nitrofish1
« Reply #10 on: April 23, 2013, 10:58:24 AM »
Already got a price list from him for porting the heads.
« Reply #11 on: April 23, 2013, 11:02:54 AM »
836 + cam, + ported head with valves, springs and retainers  + lightened alternator (cost not much), APE HD cyl studs.
Valve guides, seats might be an additional cost.
Check with MRieck on this forum about ported head.
Fresh bore and decked cylinders + head is probably needed anyway independent of bore size.
4-1 pipe. I have Yamiya's Yoshi replica on my list. This one has low short design that allow use of OEM passenger foot pegs.
What about the engine overall status?
Clutch OK?
Internal chains might need replacement together with the tensioners that have rubber wheels, today bakelite.
Primary chains + cam chain
So whith the crank cases opened you might find the crank bearings bad....
I know, I have just done this again.... this time better primary chains, reinforced almost 270 euro.
Tsubaki Camellia HD cam chain is cheap about $30-35US.
Offline Toxic
« Reply #12 on: April 23, 2013, 11:10:39 AM »
What do you want out of this project?  Your $1200 will wake it up some but fast is a relative term.  It's not going to be fast by current standards and it is plenty fast to have fun on as is.
BTW --- Mark's book is going to be the cheapest accessory you will ever buy for this bike.
If you plan on keeping the bike it will pay for itself many times over
« Reply #13 on: April 23, 2013, 11:15:26 AM »
inspiration cont.
Offline nitrofish1
« Reply #14 on: April 23, 2013, 11:19:58 AM »
At the minimum I was going to do new valve springs and the #41 webcam to liven it up.
Just looking for something that would at least be a noticeable amount faster than stock and I figured that a cam and springs would at least achieve that.
Was already going to purchase new cam chain, the primary chains look good, and so far of what I have seen of the main bearings they are in good shape as well. Staring at the bottom end I have not seen anything glaring at me as a major problem, all the components look good.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #15 on: April 23, 2013, 11:27:00 AM »
Any mods of this sort will have you changing out all the gaskets and o-rings at the minimum. Include that in your costs.
bollingball
« Reply #16 on: April 23, 2013, 11:27:45 AM »
Get both and a fatter wallet. If you want to go faster you got to pay ;) Once you open it up it just snowballs from there. If you are going to change this then you really need to change that. Decide how much HP you want then what it will take $$$ and save till you can do it all at once.
Offline nitrofish1
« Reply #17 on: April 23, 2013, 11:34:09 AM »
Already planned on that. I've fully disassembled the engine, I'm not the type of person to reuse 38 year old gaskets.... maybe I'll just stick to the cam and springs.
« Reply #18 on: April 23, 2013, 11:51:01 AM »
I modified my engine and some bike parts for same amount of cash I could buy a brand new Kawasaki 1000J back in that time 1983-1984. I had very fun with my bike then and still have it, spending a lot again.. :-) An old CB750 has its charm...
Most of the km's I have used my bike was before tuning it. 79-83 just cafe racing by act.
If starting from the beginning today.... maybe a 5-10 years old, low miles Yamaha XJR1300 with inlet mods increasing the HP from 106 to over 120... Kawasaki Zephyr 1100 look good too but less hp, some models look like the old Z1 900/1000.
« Last Edit: April 23, 2013, 11:53:29 AM by PeWe »
Offline nitrofish1
« Reply #19 on: April 23, 2013, 11:57:15 AM »
Right now I'm not really looking for another bike, just like to do this one, unless one presents itself at an insanely cheap price, which I have seen before. If not an XS1100 then I'd like to get a hold of a CB350 or 360, I've ridden cafe racers of these and they've been very loud, small, and actually pretty quick. Probably what made them so much fun.
Offline iron_worker
« Reply #20 on: April 23, 2013, 12:55:54 PM »
One of the larger restrictions of these engines is the head. If you can afford go with a good port job. A hotter cam and stiffer valve springs will really complement the port and allow it work in the higher rev ranges.
The next step would probably be to go to a big bore and this is where it starts getting expensive. You can get the cheap ebay kits (and I've heard most people have had pretty good success with them for mild builds). You will still have the machining costs of having the cylinders bored and honed to size.
If you're not going big bore you should at least re-ring your exsting engine to bring the compression back up closer to where it should be. If your piston clearance is up around .003" or over you will really start to burn oil and really should be going with fresh bores.
Big bores builds with more hp should definitely have HD studs and stronger rods wouldn't be a bad idea either.
Once you open up the top end you really should replace the chain sliders/tensioner. If you want to go one step further and split the cases then you could change the cam chain... and then there is the primary chains and tensioner. And then if the cases are open you might as well check the bearing clearances... etc etc.
And as you can see... the snowball effect has really taken place here. I'd say considering your budget I would have the head gone through with a mild port (oversize valves if you can afford it), re-ring it, all new gaskets up top, hotter cam & valve springs to suit, HD studs if you can afford it.
If there is anything (there probably won't be $$$ lol) left then a good 4-1 exhaust will save you weight and probably add some HP too if tuned accordingly.
IW
Nic
« Reply #21 on: April 23, 2013, 04:06:13 PM »
Back in the day when the Z900s came out the Honda dudes were blown away with the Z's power, the Z900 and later incarnations  were  death traps though handling wise. Kawasaki didn't learn much from the MachIII did they.
A Yoshi 812 kit and a 4 into1 allowed you to keep up with the stock Z900's and then lose em on the corners. That was a pretty impressive power gain from just a slightly bigger bore. No sub for cubes.
If you don't want to put a big bore kit in you should at least go 1st oversize to re round the bores n get it going right. My basket case 750 K2 only has 30,000Ks on it but the bores are forked as are the valves. I've got the cycleX 1st over kit ( cast pistons but still should hold up to my coot riding these days) and the #41 cam, still plan to get new springs, new valves and guides and smooth the flow in the head. It never ends though, once you open it up you just know you can't stop without doing it all if you want it to last. My machine shop is wanting $250 to do the bores, not cheap but wadiyado, dunno yep how much to do the guides.
The fact that you have to pull the motor to do anything to these things is why I'll do it all n hope I never have to again. Pretty sure the bike will outlast me this time around.
« Reply #22 on: April 23, 2013, 04:12:26 PM »
Nic, the head has more power locked up in it that any other part of the engine, NOTHING else will result in as bigger power gain than a well sorted head, my 776cc drag bike engine ran in the 10's on methanol, small bore size with hugely ported head with bigger valves, springs , titanium retainers and a good cam and 31mm CR's. The heads are very restrictive on these bikes...
Nic
« Reply #23 on: April 23, 2013, 05:30:25 PM »
Thanks mate, I do intend opening the ports up a tad. I need new valves as well, if I go for bigger valves do I need to put bigger seats in or just get the machinist to reseat the bigger valves. Where does one procure these bigger valves, are the oversize valves at cycleX worth looking at?
« Reply #24 on: April 23, 2013, 05:56:38 PM »
As mentioned earlier, talk to member MRieck, he is the resident head guru {the best}and is a mate of Kens at CycleX anyway, I am going with the 5mm {stem size} Kibblewhite oversized valves, and yes, new seats need to be fitted, the other option is stock size valves in better quality along with better springs and port work, valves deshrouded etc etc..... All depends on how much moolah you wish to spend.... ;D ;)
