I think the Dyna S plate/module(s) rotation for the CB400F is ..... Clockwise=Retard.
Does the dynamic/strobe full advance timing (at revs), look like this....
(a) V or this, (b) V
* ll ll *
if (a), rotate plate anti-clockwise to correct, if (b) and the plate is rotated fully clockwise, you still have a problem, and should re-do the installation/timing set-up, per the Dyna instructions.
