Author Topic: Please Look at This Carb Schematic. Which one is the O-Ring on the Drain Screw??  (Read 2354 times)
cafe2cafe
Hello. I just found this site. Hallelujah!!
Can someone look at these schematics and tell me which is the part for the o-ring on the drain screw when removing the float bowls? Im blind or stupid. I cant tell. Which one is it? Help! Just copy and paste this link to your browser.
http://www.bikebandit.com/partsbandit/oem_schematic_view~schem_dept_id~210643~section_dept_id~1~section_dept_name~OEM+%28Stock%29+Parts~dept_type_id~2~model_dept_year~1981~model_dept_mfr~Honda~model_dept_id~206283~model_dept_name~CB750K.asp
I have a 1981 CB750K that I turned into a mean looking cafe racer. Here is a photo:
Thanks for your help in advance. This site is SICK!!!!!
Ride it like you stole it.
Offline Jugghead
  • I just THINK I'm a
  • 350cc of pure FUN
It is #1 on the middle carb, in the lower right of the trapezoid outline.
9/72 CB350F...15k miles and rising
Offline Bodi
Jeez, there's a lot of parts labelled #1.... ahh, that's the gasket set :)
jymmeye
I just went out and looked at my 81 "K" model to see of it had an o-ring or a gasket.  I took the screw out and did not see an o-ring or a gasket of any sort.  What I saw was a tapered needle that when removed allowed the gas to run out of the hose attached to the bottom of the carb float bowl.   I hope that helps.   If you need me to look at anything else for comparison just ask. Also, I think the fiche indicates that #1 is a gasket kit for the float bowl.
Offline dusterdude
nice bike
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
