The SOHC/4 World Tour is in under way.
I don't know the answer to your question .... but ... Why?
That's not an engine. It's a sculpture... Anyway triumph is easy coz its twin cams which can be switched front to back
Yes it has been done. I agree with the "why" and will accept your "why not". There is plenty of reading in the link below.http://forums.sohc4.net/index.php?topic=80234.0Interesting to note is that there seems to be no information about that bike being finished or running for that matter. Much of the debate in that thread was about how the engine would perform, but the OP never laid down the proof.
Keep posting here if you do this! I'd love to see this insanity happening!
Hey, never forget, some lunatic built one with a sideways engine: http://forums.sohc4.net/index.php?topic=116469.msg1337072#msg1337072
Cam can be turned, l you runan external belt drive...one problem solved..Where you at.. I have worked on stranger parts before....like the CHEVarlay..
What about this then?http://www.dwmsracing.com/forum/index.php?topic=14.0
Quote from: LesterPiglet on May 01, 2013, 03:40:43 amWhat about this then?http://www.dwmsracing.com/forum/index.php?topic=14.0I linked to his SOHC4 thread above. Seems like your link might be the place to keep track of recent progress.
Here you go guys/gals something else to wrap your brain around!!!http://hondachopper.yuku.com/topic/50336/1975-8-cylinder-Honda-engine#.UYEc10pLkg8Xnavylfr(CHUCK)
