What about the complete assembly??? Airbox+booties; carbs; insulators; and aluminum manifolds from a 75/76??? That would be an 087A or 022A carb setup, rather than the later castings.
I should think that would work. However, I confess I have NOT tried that. And you would lose the bar mounted choke knob.
Another member had difficulty with the air plenum coupler availability. And, fortunately found a useable one on Ebay. I have a couple spares that I that I think are useable, though they look to be a bit deformed from having been installed in the plenum incorrectly for some long period of time.
I was wondering if I could use an old one to make a mould from and then cast new ones from RTV or a casting rubber dyed black.
They would be kind of expensive if done that way. But, if parts become unobtainium. A resto business could be spawned.
What are they worth?
