Author Topic: Gakets and seals  (Read 817 times)
bollingball
Gakets and seals
« on: May 01, 2013, 03:50:14 PM »
 1. I need to change my alt. and shifter cover for a very small but irritating oil leak. After a good cleaning do these go on dry? Or do I need some type of sealer. I think dry but like to check to be sure. The only reason they are leaking is because I had to remove them last winter and did not have new ones at the time
2. On the shifter seal being carefull to align it good I thought put a little grease on the very clean shaft to try and help it slide over without snagging on the splines. Anyone use something else on the shaft?
Thanks in advance
Ken
Offline Vinhead1957
Re: Gakets and seals
« Reply #1 on: May 01, 2013, 04:25:51 PM »
I use grease with cardboard gaskets it assists in holding it in place during installation
Offline purf_man
« Reply #2 on: May 01, 2013, 04:57:14 PM »
I like to use engine oil on seals that interact with engine oil.
1975 CB550
1978 RD400
