The SOHC/4 World Tour is in under way.
Here is a pic of a '77 750 hub; I believe the 550 is similar? The sprocket and drive plate should pull straight out of the hub as a unit. The drive plate has it's own bearing; be sure to check that as well.
In 30 years never seen any worn out yet
