75 cb750
I think this is common problem. I've had this bike about a month and while it keeps
Getting better issues remain.
Today this is my problem. Took bike out for a brief loop around the block, got to the stop sign
Dropped into first, as I came to a complete stop I pulled in the clutch and the bike stalled.
Waited a moment, set into neutral, restarted with a little throttle, vroom vroom, pop into first
And away I go.
Get to my driveway, shift down to first, as I approach the bottom, still in first, pull in the clutch,
Stalls again.
Repeated the route a second time and got exactly same results.
Thought I would ask for some opinions before putting on my blindfold and mittens, and start hammering away at stuff.
Idle jet, clogged passage?
Float height?
Vacuum leak?
Throttle stop? - don't think this is it.
Air fuel mix? - don't think this is it.
Carb sync? - doubtful.
Dirty plugs? I don't think so. But Im so not an expert.
She idles pretty nicely from a cold start around 1k. +/- 100 rpms. Runs pretty nicely too.
But obviously I don't want to be starting up at every intersection.
