Author Topic: cleaning parts liquid... what do you use?  (Read 6012 times)
Offline xsmooth69x
« on: May 05, 2013, 10:13:16 PM »
thinking about picking up a 20 gallon parts washer. so what do you all use for washing?
i have been reading about the water based stuff and heard that either the green stuff or purple stuff etches or stains some kinds of metal?
should i just use diesel? i heard diesel left a kind of film on the parts when your done washing so should i just go mineral spirits.... but its $$$$
also i live in MN and the parts washer will be in a un heated garage. if i go with water based cleaners do i have to drain the parts cleaner or will the stuff that you mix in with the water prevent it from freezing?
1975 CB550 (FINISHED?!?!?)
Re: cleaning parts liquid... what do you use?
« Reply #1 on: May 05, 2013, 10:32:54 PM »
kerosine.
Offline tomkimberly
« Reply #2 on: May 05, 2013, 11:43:32 PM »
I prefer to use diesel, some like kerosene. Any remaining film is easily washed off with soap and water.
Tom
Nic
« Reply #3 on: May 05, 2013, 11:46:13 PM »
I just pour some of my lawn mowing 2 stroke petrol into a baking tray and away we go.
Offline johno
« Reply #4 on: May 06, 2013, 03:08:54 AM »
Buying degreasing oil is expensive for a part time user, I mix two thirds diesel, one third degreaser with a dash of caustic...........wear gloves man !   then to finish off I use a spray gun with truck wash straight then pressure clean with water gurni pressure cleaner ................. I use a Moroso brush kit to scrape oil galleries and passages,......................... 10 times if glass beads have been used. ;D
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline trueblue
« Reply #5 on: May 06, 2013, 03:59:55 AM »
At work I just use Jet A1, aka kero mixed with a little Baridol, which is a degreaser.  With the baridol mixed in once you are finished just a quick wash with the hose and you're done ;D.
1979 CB650Z
bollingball
« Reply #6 on: May 06, 2013, 04:31:16 AM »
kerosine.
+1 The parts washer instructions will warn against this mine did but I have been using it for years with the same pump. On a side note get the flex hose with the brush it is handy.
Ken
Offline xsmooth69x
« Reply #7 on: May 06, 2013, 06:20:46 AM »
ya i buying the harbor freight parts washer. i know it says water based only but I have read plenty of reviews that you can run mineral spirits or petroleum product through it without destroying the pump or something. even if it does a pump is cheap.
ok ill try some diesel out. is it really stinky?
« Reply #8 on: May 06, 2013, 06:35:28 AM »
Just dont use diesel to clean brake drums  ;D
Here is how I know:
In military this dumb officer made us clean truck brake drums in diesel fuel  -  we knew better, but order is an order  ;D
You would not believe how surprised he was when trucks would have no brakes.
Offline xsmooth69x
« Reply #9 on: May 06, 2013, 11:30:29 AM »
Here is how I know:
because you didnt rinse of the diesel when you where finished?
also anyone use this psc 1000 stuff you get at tractor supply stores. i heard alot of forums that raved about the stuff
« Reply #10 on: May 06, 2013, 12:20:09 PM »
diesel ages darkens and grows fungus in it,kerosine almost dries away itself.
Offline greenjeans
  • 1972 CB750K2
« Reply #11 on: May 06, 2013, 02:16:19 PM »
kerosene.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #12 on: May 06, 2013, 05:08:09 PM »
i use diesel or kerosene mainly because that is whats available here on the farm
MATT
Offline lone*X
« Reply #13 on: May 06, 2013, 07:55:47 PM »
Kerosene all the way.  Diesel stinks too much and it doesn't last as long in the washer.   Only redeeming factor with diesel is availability.  You can get it anywhere.  But kerosene beats it hands down.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #14 on: May 06, 2013, 08:23:26 PM »
Turpentine works well but kerosene is cheaper in the quantities you need for a parts washer.
Volatility is good with either as they don't have the explosion risk of other more dagerous aromatic solvents. But, just be safe with open flames and grinding near them.
Offline kghost
« Reply #15 on: May 06, 2013, 08:35:09 PM »
Varsol in the USA. Basically mineral spirits but made as a solvent.
Shellite in Australia, but it's flammable naphtha based
« Last Edit: May 06, 2013, 08:37:26 PM by kghost »
Stranger in a strange land
Offline dusterdude
« Reply #16 on: May 08, 2013, 02:51:26 PM »
A customer of mine uses purple power and water in his cleaner
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
bollingball
« Reply #17 on: May 08, 2013, 03:24:18 PM »
It is called mechanics colone ;D
Ken
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #18 on: May 08, 2013, 03:28:02 PM »
I use Blaster in the five gallon pail.  I don't need a washer because the lid can be pulled off and put back on.  Much higher flash point than anything that goes into an internal combustion engine.  I put the part in the bucket, brush it down to clean it and move on to the next part or close things up.  Works on my car parts too.   Faster, better, cheaper in my opinion.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline xsmooth69x
« Reply #19 on: May 10, 2013, 04:48:41 PM »
whats a blaster?
Offline george
  • Back To My Roots !
  • K8 The Project
« Reply #20 on: May 10, 2013, 05:13:52 PM »
Wish I could find some of the Varsol from back in the 70's, Todays stuff is about as effective as the new and emproved carb cleaner "Berrymans Chem Dip" useless stuff. My Mom could always tell when I had hung out at the Cycle Shop by my smell !
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
Offline dusterdude
« Reply #21 on: May 11, 2013, 07:15:54 AM »
whats a blaster?
i think he means pb blaster,good stuff
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Lostboy Steve
« Reply #22 on: May 11, 2013, 07:47:58 AM »
Purple power seriously destroys aluminum tho. I used Diesel or Kerosene in my parts washer. No it is not located near heat or flame source and well ventilated. Just make sure to wear gloves. Works very well.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #23 on: May 11, 2013, 07:49:16 AM »
My grandfather used to use the #$%* out of Varsol.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Bodi
« Reply #24 on: May 11, 2013, 09:15:16 AM »
The harbour freight/princess auto parts washers say "water based" for safety regulations I think, but they work OK with solvent. The pump and hose are not solvent proof though. The pump may fail soon and the hose gets stiff as glass if you pick the wrong solvent - kerosene seems ok, varsol not so good.
Beware of the vapours that are of course flammable. If your house burns down because of a fire started there you may have insurance problems.
Auto shops almost all use water based cleaning solutions but they usually have a service take care of it - replacing the solution periodically and taking care of disposal. Disposing of dirty water based or solvent cleaner is difficult to do "legally". The water based solvents do an amazing job of removing grease but they also attack aluminum since they are usually strong alkalis, so take care if you use them. Keep exposure time to a minimum and rinse super well.
Offline Muckinfuss
« Reply #25 on: May 12, 2013, 10:18:48 AM »
Blaster parts cleaning solvent.  5 gallon metal pail.      http://www.blastercorporation.com/Parts_Washer_Solvent.html
For safety and ease of use:   http://www.thebenchtoppro.com/     it's water based...no fire hazard and the fluid can be disposed of without hazmat certification
« Last Edit: May 12, 2013, 10:42:18 AM by Muckinfuss »
1974 CB550
1989 Corvette
