Author Topic: Small crack in front brake disc - critical?  (Read 2265 times)
Offline Glaede
« on: May 06, 2013, 03:41:57 AM »
Hi guys
I noticed a small crack in the front brake disc yesterday when mounting the disc. Is this crack critical? :/ I would like to replace it, but its kinda expensive, so if its not critical, I'll just continue using it..
I've attached a picture of the crack:
Offline Eydugstr
Re: Small crack in front brake disc - critical?
« Reply #1 on: May 06, 2013, 03:45:37 AM »
I'd go ahead and replace it.  Used rotors aren't that expensive.  Good eye at spotting it before it became a problem!
Offline Glaede
« Reply #2 on: May 06, 2013, 03:47:24 AM »
Okay, well here in Denmark, used parts is not so easy to come by ;-) So I would probably have to import it from Germany or UK. What is the std. thickness by the way in mm?
bollingball
« Reply #3 on: May 06, 2013, 04:12:15 AM »
It should be stamped on the rotor.
Ken
Offline Fritz
« Reply #4 on: May 06, 2013, 04:13:38 AM »
Hi!
Although this crack might not seem to be really serious, I would not take any chances when it comes to brakes.
The disc is stainless steel, so I would not expect a lot of wear. In my 500/550 workshop manual I could not find any numbers for minimum thickness.
Wobble seems to be more of a concern. But you could always have the disc machined back to get an even surface. There's a lot of 'meat' on it.
On ebay.de used discs ("Bremsscheibe") range from 60€ up to 100€ (drilled). On ebay.co.uk they range from £30 to £50. I think that's not too much for your safety ;)
Cheers
Carsten
1976 CB550F
Offline Glaede
« Reply #5 on: May 06, 2013, 04:16:21 AM »
Hi!
Cheers
Carsten
I agree which is why I made this topic to convince my self ;-)
I'll order a used disc from ebay! Thanks guys..
Btw, the minimum thickness is 6 mm, but I was wondering what the standard thickness is of a brand new disc.
« Last Edit: May 06, 2013, 04:25:47 AM by Glaede »
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: May 06, 2013, 04:24:01 AM »
I have seen discs that have been skimmed as thin as 4mm, it seems a common weight saving effort.
« Reply #7 on: May 06, 2013, 07:19:44 AM »
Is.it a crack or raised line.. May be from a crack in the mould or die.. If it is sticking UP.
« Reply #8 on: May 06, 2013, 07:25:11 AM »
Hi!
Cheers
Carsten
New thickness is 7mm.  Stamped minimum thickness is 6mm.
I love my drilled 4mm rotors from Godfferys Garage
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/Brake+Rotors+_+Thinned+and+Drilled/
Offline Powderman
« Reply #9 on: May 06, 2013, 08:09:50 AM »
It is definitely a crack but not in the rotor, it is in the aluminum carrier. I would replace it as the cracked aluminum will probably deteriorate faster than the steel rotor will
Offline lucky
« Reply #10 on: May 06, 2013, 08:15:59 AM »
FIRST clean it to bare metal before making any decisions.
You cannot do a good visual inspection until it is clean shiny metal.
NO paint.
Offline Glaede
« Reply #11 on: May 06, 2013, 08:19:06 AM »
Yeah.. I've found a used one in Germany, so hopefully it will be here by the end of the week :-)
Got the bike on wheels yesterday btw - bought the bike in february and have been restoring it for the last three months (my first bike):
After inspection (hopefully friday when I have a day off) I'll continue cafe racing it. I have some clip ons - just need a new seat and taillight really.
It looked like this when i bought it - pretty ugly, but running:
Offline Powderman
« Reply #12 on: May 06, 2013, 12:06:42 PM »
Do you plan on rear sets. Standard pegs with clip-ons will put you in an awkward/uncomfortable position.
Offline Glaede
« Reply #13 on: May 06, 2013, 12:13:15 PM »
I haven't really decided yet. I think the ones that you bolt on to the passenger foot peg makes an even worse riding position, and I don't want to modify the frame since it's illegal and it's freshly powder coated. But I'll decide when I've ridden it I guess :-)
Sendt fra min HTC One
Offline lucky
« Reply #14 on: May 06, 2013, 01:25:58 PM »
Can you please get back on subject, and tell us if the disc was cracked or not?
Offline Glaede
« Reply #15 on: May 06, 2013, 01:29:21 PM »
? It is cracked - never said it wasn't. Look at the picture. I was asking if it was critical.
Offline Fritz
« Reply #16 on: May 06, 2013, 01:45:29 PM »
Not my choice of color but the 550 is a real beauty. Isn't she?
1976 CB550F
Offline Glaede
« Reply #17 on: May 06, 2013, 01:50:11 PM »
Yeah it's a nice bike. The color is only temporary. I bought the tank black and don't have the money at the moment for a professional paint job. I think it's prettier than before though :-) I'll probably ride it like this for the summer..
But enough off topic for now - don't want to ruin luckys day ;-)
Offline Fritz
« Reply #18 on: May 06, 2013, 02:07:19 PM »
Ah, Lucky's just missing a bit of humour :)
Too bad I'm living next to the former Danish border. Århus (or is it Aarhus?) is just too far to join the first ride on your bike :)
But maybe, if you happen to be around the Flensborg/Sønderborg area some day, I'd be glad to ride with two 550s along the Flensborg Fjord...
Cheers
Carsten
1976 CB550F
Offline Glaede
« Reply #19 on: May 06, 2013, 02:11:26 PM »
Cheers
Carsten
Cool, where do you live? Well I am in Flensborg sometimes when I need cheap beer ;-)
Offline Fritz
« Reply #20 on: May 06, 2013, 03:04:34 PM »
Well cheap beer and riding motorcycles does not go along very well, no matter the condition of your brakes, I guess ;)
I'm living in Hamburg. It's just a 90minute's ride to up to the Danish border...
Cheers
Carsten
1976 CB550F
