Author Topic: Hard to start with kicker,electric fine  (Read 4020 times)
Offline acollin
« on: May 08, 2013, 06:36:37 PM »
My 1974 cb 750 is hard to kick star from cold. It is a stock set up. The electric start works fine. Kick starts one kick when warm.
It runs great. I'd like to have that cold kick start option back
Please advise--
Thanks
Andrew
Offline SONIC
    • Walnut Wood Works
Re: Hard to start with kicker,electric fine
« Reply #1 on: May 08, 2013, 06:43:27 PM »
What are we talking here?
3 or 4 kicks or more in the 20 ballpark?
Offline acollin
« Reply #2 on: May 08, 2013, 06:46:43 PM »
Plenty, I never counted but I usually tire --- push the button and head out.
Offline bjbuchanan
« Reply #3 on: May 08, 2013, 09:59:33 PM »
Kinda weird rly. Just a thought tho, maybe your idle is a little low, which if set properly will be for a cold start and because of concentrating on kicking you aren't cracking the idle enough to get the bike to start?
If it needs just a crack of throttle to start and you are hammering away on the kicker without twisting (which is easy enough to do) it probably will take forever, if ever, to start
Easy to work the throttle pressing a little button tho
Offline mronegear
  • Honda CB 550 F 1976
« Reply #4 on: May 09, 2013, 04:40:37 AM »
some guy told me a routine which works fine when the bike is cold...
1 turn on fuel
2 kick twice with throttle full open, ignition off
3 turn ignition on
4 twist throttle just a little open
5 kick all the way down
really works fine with my cb 550 when cold, max 2 kicks!
Offline Vinhead1957
« Reply #5 on: May 09, 2013, 05:15:03 AM »
Put choke on , twist throttle, turn key on kick and give throttle at same time. That extra gas should boost it to start
Offline acollin
« Reply #6 on: May 09, 2013, 06:07:39 AM »
My idle is to spec and stable once warm.
I'll try your suggestions today and report back,but nothing suggested so far sounds all that unfamiliar.
I guess you are all saying more fuel and the proper time.
Thanks
Offline chewbacca5000
  • I polish covers!
« Reply #7 on: May 09, 2013, 06:27:45 AM »
I posted the same question and the answer can be found here http://forums.sohc4.net/index.php?topic=100190.0
Without cracking the throttle my bike won't start at all.  A little choke for a second helps too.
Offline bjbuchanan
« Reply #8 on: May 09, 2013, 10:59:59 AM »
Not to thread hijack but I went to school up in Syracuse, how do you ever find the time to ride when it isn't pouring out? Or do you always have the wetsuit strapped on.
I was up there 2 yrs ago for the crazy winter, whole campus shut down
Offline goldarrow
  • one day, i'll be an
« Reply #9 on: May 09, 2013, 11:37:58 AM »
gotta love the kicker, once you're tired of using right leg, put on center stand and use left leg.  great excercise.  :) ;)
CB550 K0
Offline SONIC
    • Walnut Wood Works
« Reply #10 on: May 09, 2013, 01:51:10 PM »
Nah when your right leg gets tired you just turn around backwards in the seat.
Everyone knows that sheesh
Offline goldarrow
« Reply #11 on: May 09, 2013, 02:00:37 PM »
you just turn around backwards.
how does everyone know my secret move that i do with my lady???  ::) ;) ::) ;)
CB550 K0
  • I polish covers!
« Reply #12 on: May 09, 2013, 08:12:57 PM »
Yeah that is exactly what we do.  And come winter we tie a ski to the front wheel and off we go.  If you think Syracuse is bad try an Oswego winter that is where I went to school.
Offline Reganator
  • Just another guy with a CB750 kinda cafe.
« Reply #13 on: May 09, 2013, 09:42:38 PM »
+1 on all the crack throttle responses.
My idle is set just above 1k and if I just kick it takes forever to start.  So, what I started doing is kicking it once, then turning the key on, choke, crack throttle maybe 1/8, just a couple degrees of rotation down, then kick again.  Starts every time, even when stone cold.
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
     Stock needle and settings.
My-neighbors-love-me-Kerker 4 into 1
Stock airbox
The best way to make a small fortune on the stock market is to start out with a large fortune.  Trust me, I'm an actuary.
Offline crazypj
  • I'm brill, me
« Reply #14 on: May 10, 2013, 12:56:11 AM »
I used to start them by hand after service to show owners how easy 750 starts.
Main issue was always attempting to 'slap' start like a 125 MX bike, or, having a 'wire' between knee and elbow, every time kickstart goes down, throttle gets opened too far and floods motor
bollingball
« Reply #15 on: May 10, 2013, 04:50:18 AM »
1 turn on fuel
3 turn ignition on
Sounds more like four. ;)
Offline acollin
« Reply #16 on: May 10, 2013, 06:26:51 AM »
All is well---thanks
It seems as if I was not cracking the throttle. My technique could use some work but I'm in the ball park and there is light at the end of the tunnel (no train).Had to travel yesterday, but had some time in the morning and it started pretty easy.
ONE CAUTION: WITHOUT THE PROPER CARE, KICK STARTING IS A GOOD WAY TO CRACK THAT LEFT SIDE COVER!!!!
In response to another line in this thread, I do mount a ski rack to my cb 750 and if I can figure out how to post a picture I'll get it out there. I work on MT Hood in Oregon and we ski and board  12 months. Summer motorcycling and skiing in the same day.
Be well all
Andrew
Offline volthause
    • gallery
« Reply #17 on: May 10, 2013, 07:38:29 AM »
Three twists of the idle knob (faster idle), choke on, usually kicks over the second or third time from cold.
scott - 1974 CB550
Project Thread - http://forums.sohc4.net/index.php?topic=122740.0
Offline Reganator
« Reply #18 on: May 10, 2013, 09:49:26 AM »
I did that once and my 750 kicked back a little.  Hurt like a B*$#@!  Good luck on that one though, I won't do it with my hand anymore.
Isn't this effectively the same thing as cracking the throttle though?  Just thought I'd point that out.  I don't know about you, but my idle screw is hard as the dickens to turn so I take the Ronco approach:  Set it and forget it.
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
Stock airbox
Offline iron_worker
« Reply #19 on: May 10, 2013, 10:08:17 AM »
It is exactly the same thing but with his way you can get exactly the same amount of throttle each time and you're not trying to hold the throttle still while kicking the bike. I think it's clever.
IW
Offline Reganator
« Reply #20 on: May 10, 2013, 11:43:15 PM »
I suppose.  Then you have to mess with that idle screw constantly though.  Mine is simply to difficult to get turning.
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
Stock airbox
bollingball
« Reply #21 on: May 11, 2013, 05:32:03 AM »
IW
This may be the reason Honda used the fast idle cam in 78 750 and other years too. You pull the choke full on and it sets the idle to about 2600 gives it a little gas All automatic when it starts to warm up you just start opening the choke. No matter what system you have When it runs about 30 -45 seconds just start going and shut the choke off asap.
Both of you have a good ideas what ever works for you is cool.
Ken
Ken
« Last Edit: May 11, 2013, 05:37:54 AM by bollingball »
  • I polish covers!
« Reply #22 on: May 11, 2013, 05:57:41 AM »
IW
The only problem IW is playing with that screw just does not look cool in front of the ladys or the Harley pack.  I am getting the whole Fonzie Zen thing down and am happy to say becoming a "one kick wonder" Aaaaaaa
Offline Reganator
« Reply #23 on: May 11, 2013, 08:30:09 AM »
I don't worry about what they Harley guys think myself.  When they do give me a hard time I say, "Ok, go get a 1972 Harley Davidson anything, or any Harley of any year 72 or lower and then we'll compare notes."
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
Stock airbox
Offline Vinhead1957
« Reply #24 on: May 12, 2013, 05:40:12 PM »
Hey wait a minute! I'm a Harley guy!
Was a Honda guy in the 70's 80's gave up the need for speed when I had kids.    Fast Forward 20 years.
Hey I wanna get back into biking. Buy my dream machine. 05 Fatty. Fits my style. 30 to 50 coastline vista. Still going!
2012 need a winter project.  73 750 comes up.  My wife calls it a POS.   what do you want that POS for. I
Think she is blind. I prove her wrong!  The 750 is a part of history. Honda is part of History! The joy is bringing it back to where it was!
I'll ride my Fatty as I always do!   I'll ride the Honda differently, no as fast, not as foolish. I am a motorcyclist!
By the way comparing quality in engines or manufacturing.  I find the Harley's easier to work on! The complexity of more cylinders adds to the riddle.  I like the challenge of solving riddles.
