Author Topic: Fuel cap full of rust..,Any of you in NC. w/ an Ultrasonic Cleaner ??  (Read 4458 times)
I have 2 Fuel  caps & both have internal rusty dust chunks in them.I ride for a while & she runs good & then....,well you get the picture.I've cleaned out my entire fuel system too many times,the tank is Nice w/ no rust problems;that gas cap is peppering lots of particles down gravity feeding into my system & now I want a solution.I'm looking around here in the Greensboro/Triad area,I live in High Point,NC. & so far..,no dice.
Please PM me(or email) if anybody's close to the area & can let me know who they are... Man,I'm desperate !  :'(
                                                  Thanks a Ton,
        Bill
« Last Edit: May 09, 2013, 03:00:36 PM by grcamna2 »
Offline jason41987
what about rust reformer? the stuff that converts iron oxide into a black material that blocks new rust from forming?.. youd have to get the loose chunks of rust out though, possibly with the ultrasonic cleaner, shake some beads or BBS inside it, etc
Hi Jason,
      These 2 little caps have that rusty dust in them & I know the ultrasonic cleaner is the full cure.The tank is nice..,except its got that never ending rusty dust seeping down from the cap  >:( Man,am I EVER tired of that stuff fouling the running of my little Honda !! I need to use the bike for now over the car & it's not much fun..,if you know what I mean.
The Ultrasonic cleaner machine WILL fix this problem.
Offline jason41987
hmm, you could buy a small ultrasonic cleaner yourself, one large enough to do the fuel cap, and maybe even large enough to do a carburetor at a time.. and then if it rusts again in the future youre all set
I would, but I'm living in an Apt. & they won't allow it & I don't have a shop.
I just want to find someone who Already has one & let them do the job.
Offline Harsh
  • 74 CB750 and two 72 CB350's
You can take the gas caps apart to remove the rust chucks and then treat them with whatever you rust remover of choice is.  I prefer prep & etch.
http://forums.sohc4.net/index.php?topic=35056.0
Offline Xnavylfr
What year /cap is it?? I may have one that we can swap off of a tank for you. I live in Advance, just west of Winston-Salem.
Xnavylfr(CHUCK)
Offline Lostboy Steve
Just get an empty (preferably plastic) paint container and electrolytic-ally remove the rust from it. Thats what I did.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Harsh,
     This little cap is the type that won't come apart.
Twisted,
     That's something I've never done yet..& I think I'll research it a bit more;still an Ultrasonic cleaner Will do the job  ;)
Offline 750K
Buy a small jewelers ultrasonic, the one I have is under 12" square and maybe 8" tall. It works great, I use it for all sorts of stuff motorcycle and non m/c related. Or try soaking it in white vinegar for a couple days, that'll get rid of rust pretty quick.
77 Cb750, 78 Kz1000
Thanks 750K,
       I'll think about buying one later.I'm still looking to see if a member close to me in NC. might have one...
                                              Bill
Offline 750K
This is the one I use, I paid $100 for it locally and have used it to clean jets and other small carb parts, petcocks etc. Works great, well worth picking up.
http://www.sonicsonline.com/gemoro-ultrasonic-jewelry-cleaner.html
77 Cb750, 78 Kz1000
Offline jamesbekman
Just use some apple cider vinegar or some phosphoric acid.  Works like a charm.  The acid is a tad bit quicker.
Its safe, and easy. All it takes is a battery charger and washing soda.  ;)
Twisted,
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Thanks for the feedback on that Cap !  :)
bollingball
Harsh,
Post a pic. I have never seen one that does not come apart. Once you see how it comes apart then you can clean it IMHO
ICBW but got to see it to believe it.
Ken
Thanks for your interest bollingball,
              I have yet to learn how to post pics,otherwise I would have done it w/ this one.I realize it does make explaining the problem Very easy  :) This little cap is  riveted together.
Do you have an Ultrasonic cleaner ?
« Last Edit: May 12, 2013, 11:29:52 AM by grcamna2 »
bump.
Will anybody here locally in NC. do me a small ultrasonic gas cap cleaning favor ??  ::)
Offline 78whiteorbs
I am in Mooresville if that helps and have a Ultrasonic. Are you running inline filters? Sure its not rust in the tank? Tried soaking caps in evaporust?
Hey whiteorbs,
         I haven't tried evaporust because I hate to buy a whole gallon for just these 2 little caps.I have cleaned this little tank w/ wood bleach & it's nice.
                    I'll PM you
Offline jason41987
id try the vinegar idea first.. its the cheapest, worst case scenario you waste half a cup to a cup of vinegar
Offline ncstatecamp
The riveted ones do come apart, you just need to drill out the rivets. Then when you reinstall just use a bolt. Hondaman sells a kit or you can go to town and country/ace and they have a ss bolt and nut that'll fit.
Offline 78whiteorbs
fyi O'Reily's sells it by the pint , like 7-8 bux or something . If it didn't do the trick you can always reuse it on something else.
I thank All of you members for all your great advice,I learned plenty for the next jobs ahead. 78whiteorbs,I PM'd you twice & left my contact#...? I want to ask you to run my fuel cap in your ultrasonic cleaner Please;that is the way I pefer cleaning it on this job.
I'm hoping to FINALLY clean out my cap w/ that process as soon as I can.I'm sure that's what I need now.The sediment from the "wood bleach" tank cleaning process caused all the rusty type particles to float to the top as the tank sat w/ the cap on it(I live & learn..,next time I'll remove the cap  ::))for 24 hrs.That really did a Nice job on the tank ! ,but collected all the sediment into the cap...
& now for the Finale... :)
Any other members here in NC. w/ an Ultrasonic Cleaner ??
  Please PM me;I use this bike ALL the time for my basic transportation & I Need the entire fuel system cleaned up once & for all CLEAN..,the cap IS the culprit.
                                            Bill
