Lucky, When the bike dies it doesn't lock up. It makes a sound like all the cylinders are moving without the spark. Almost like a fast humming sound if that makes sense.
The picture of the plug was the #4 plug. After I saw that I pulled #1 and it was much cleaner.
When its running I can give it quick throttle and it responds very quickly. I do believe the builder did rebuild the carbs with proper jets.
And no backfiring except when engine braking going down a hill.
Also I forgot to note. I thought it a small issue but after I have the motor running for a while, if I leave the petcock on "on" it will leak fuel out the bottom of the carbs. My solution to this is to put petcock on "off" after riding. Im not sure if that could effect it any way.
Thanks for all the info. I'll be purchasing the resistor pack tonight. Figure they cant hurt.
The Resistor Pack will help reduce the current to those overkill coils, leaving a little more power available for other things. That might help? You can use the standard 1 ohm coil, but in a weak charging system like this one, I might recommend the 2 ohm version (like for the smaller Fours that got stuck with these 3 ohm coils somehow). While this reduces the spark voltage somewhat, it is still more than the stock coils (although the duration is shorter).
One thing that Dyna coils are famous for: if the sparkplug caps are 0 ohms (or just metal caps) or if the short wires from the coils to the plugs are the silly silicone resistance wire Dyna sells, the coils tend to overheat after a while. So, while this next suggestion may seem complex, it is a semi-analysis of the setup you seem to have:
1. If you use the 1-ohm Resistor Pack, use the 5k ohm (5000 ohm) sparkplug caps at the minimum. If you can find the 10k (10,000 ohm) version, so much the better. Use sparkplug gaps of about .040" to .045".
2. If you use the 2-ohm Resistor Pack, use the 10k ohm plug caps. This will extend the spark duration, leaving the peak voltage at about 2kV more than stock. Use stock plug gaps with this arrangement (.028" nominal).
Either of these arrangements will cool off the coils, which will reduce their current when hot. Maybe this will help?
