Author Topic: 79 honda cb750 running problem, help!  (Read 353 times)
Offline drmeloh
« on: May 13, 2013, 01:08:59 PM »
I recorded what my bike does. it does it more in the second video.
when I turn it on I have to adjust the idle screw so It can rev to approximate 1200rpms and be kept on.
I take off the choke once the engine is hot, then I rev it, it tends to stay stuck at 2000-3000 rpms so I adjust the idle screw again to 1200 rpms.
it also tends to accelerate/rev on its own when its warming up so I adjust the idle.
and once I get going and hit 1st gear it does the same thing so I have to adjust again. it does this for a while throughout the ride but then it becomes somewhat normal after adjusting the idle screw for several times.
HELP PLEASE!!!
https://www.youtube.com/watch?v=g8W7rttkz2A
https://www.youtube.com/watch?v=nOAvRirCKfA
bollingball
Re: 79 honda cb750 running problem, help!
« Reply #1 on: May 13, 2013, 01:13:05 PM »
79 750 is not a SOHC :o
Try posting in other bikes you might get more results. :)
« Last Edit: May 13, 2013, 01:15:25 PM by bollingball »
Offline d3buttz
  • More than just an
« Reply #2 on: May 13, 2013, 06:22:40 PM »
This thread will be moved or deleted since its dohc, sent you a pm
I had the same problem. Hope it helps.
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
