Author Topic: How much is a used 750 motor worth?  (Read 4204 times)
Offline jimbojangles
« on: May 15, 2013, 02:25:14 PM »
I know location can play a role in this (Some people on the west coast will pay anything), but how much would you pay for a used parts motor in the south? I finally got an old guy that uses CB750 heads for doorstops to sell some stuff after a year of trying. It's not all in the best condition, but what would be a fair price for a complete CB750 motor in nonrunning condition? He has several, but hopefully I can find one that still turns over and doesn't have any cracked or bent fins.
I mostly just want the head and barrels for an upcoming rebuild, but he wants the same price for the head as the entire motor. I figure it never hurts to have spare parts.
Oh...is there any I should keep an eye out for in particular? Maybe early serial numbers?
Thanks for the info.
1974 CB350F
2013 VFR1200F
Re: How much is a used 750 motor worth?
« Reply #1 on: May 15, 2013, 02:42:48 PM »
i picked up a complete, but disassembled F3 motor + carbs + extra set of rockers (+ Zero miles after a complete valve job) for $100 ;D
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: May 15, 2013, 02:48:28 PM »
$200-$300 tops.  Unless they're REAL hard to find elsewhere.
« Reply #3 on: May 15, 2013, 02:53:41 PM »
The guy wants $200. I know I can drive a couple hours and get a nice head and barrels for $150. Or a complete running "black motor" for $500.
I thought the extra parts would be nice like side covers, shift forks, etc., but I'm not sure of the quality. A lot of stuff has sat outside unplugged for years.
1974 CB350F
2013 VFR1200F
Offline Greggo
  • Somebody's
« Reply #4 on: May 15, 2013, 03:52:11 PM »
If you trust the guy selling the running black motor, that sounds like a winner.  I'd pay much more for a known-to-be-good, running motor.
Offline Vinhead1957
« Reply #5 on: May 15, 2013, 04:24:10 PM »
200 inspect and jump on it !
Offline MJL
  • Don't listen to me, I'm no
« Reply #6 on: May 15, 2013, 05:03:44 PM »
What's with the black motor? I have one, a non-runner, that I stripped out for a mockup, but I still have all the parts if they are better than a regular motor.
Offline BPellerine
« Reply #7 on: May 15, 2013, 05:47:20 PM »
black motor might be a late fmodel engine .more hp than earlier f .some late k bikes had black engine .check engine no. to find out.
1978 CB 750K ard and webers
another anfob
« Reply #8 on: May 15, 2013, 06:01:37 PM »
The guy said its a SS engine. I don't know a whole lot about them. I heard the bottom ends are better on these, but don't know why or if it's true. I also heard the top ends wore out faster. I was planning to build up my 73 K engine, but would the "SS" be better? Also, would I need to get later model carbs and boots? I just want something reliable with a bit more power. my k motor isn't in bad shape just leaking oil at the seems and a bit tired.
1974 CB350F
2013 VFR1200F
« Reply #9 on: May 15, 2013, 06:13:07 PM »
$200 is a fair deal, get it.  I've not seen an original K motor black. SS= F
Offline Red Good
« Reply #10 on: May 15, 2013, 06:52:47 PM »
Don't think any K motors were black from the factory . Black was a late F thing .
Offline Roach Carver
« Reply #11 on: May 15, 2013, 07:01:04 PM »
Is this at tontitown machine???
Offline tomkimberly
« Reply #12 on: May 15, 2013, 07:27:13 PM »
It's not what we think is a fair price, it's what you are willing to pay.   8)
Tom
« Reply #13 on: May 15, 2013, 07:40:59 PM »
The SS motor is at a place in Oklahoma.
Have you been to tontitown machine before? The owner is a nice guy. they saved my butt one weekend when they actually had a master cylinder rebuild kit in stock. I couldn't believe it.
I heard there's some other old guy in Springdale with a stockpile of parts, but I've never learned the name or place.
1974 CB350F
2013 VFR1200F
« Reply #14 on: May 15, 2013, 07:52:39 PM »
You're right about the price. I just wasn't sure what would be fair for something not running.
How bad does being left out in the weather affect the insides of the motor if the intakes aren't plugged?
1974 CB350F
2013 VFR1200F
Offline tomkimberly
« Reply #15 on: May 15, 2013, 07:54:56 PM »
Ever been to Vegas?    ;D
« Reply #16 on: May 15, 2013, 08:02:30 PM »
That would be a deal killer for me.
Offline Old Scrambler
« Reply #17 on: May 16, 2013, 10:55:16 AM »
Ask to pull the valve cover with your labor and look for retained oil (good) or rust (bad).  Pulling the head is well worth $100 in labor to the seller. If you don't buy the complete motor you won't have any spares.
Alternative is give your K3 a complete new gasket set with pucks, new rings & hone, maybe a valve-grind if needed..........and be happy.
A friend had several spare crankshafts that were all in good spec. I had one. We traded all for cash and several hundred dollars worth of parts to a local motor builder. Who would think an oil tank for a CB750 K0 would be worth more than a crankshaft?  Ebay buyers, that who!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #18 on: May 16, 2013, 11:13:45 AM »
In Virginia I paid $200 for F3 engine, wheels from F3, complete fork with tripple, wire harness and odds and pieces.
But the engine needs a total head job to last longer than few thousand miles.
« Reply #19 on: May 17, 2013, 08:04:54 AM »
I went and looked at the parts motor I was offered and based on current recycling prices I would say it was worth about $60 -$70.
I was offered my choice of motors from a pile behind a shop. The "best" had the side covers removed, intakes and exhausts left unplugged and had the spark plugs removed just to make sure it was thoroughly left open to the elements. Some of the others actually had plants growing out of them. I kept my money and took the wife out to dinner.
1974 CB350F
2013 VFR1200F
« Reply #20 on: May 17, 2013, 08:08:01 AM »
where are you at and why have we not met. We have a pretty active group of guys here in NWA that ride. we are going on a 3 day ride in about 2 weeks.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #21 on: May 17, 2013, 08:08:52 AM »
Key point here boys...when looking at a pile of 750 motors always look for the 1007400 or less numbers, they are worth buying! Trust me... ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #22 on: May 17, 2013, 08:49:07 AM »
What's with pre-1007400 engine numbers? Sandcast?
I actually live in Elm Springs. I've attended a couple of the Ozark Vintage Cycle events, but always seem to be busy during a lot of meet ups or rides. I would love to go on a ride and bounce ideas off other owners since my bike almost always seems to need something and I have to figure a lot out as I go. I don't know many people that ride except for one co-worker of mine who bought himself a cafe'd GL1000 off Ebay.
So yeah, yesterday the parts motors were at Tontitown Machine. He's got several bikes and motors in various states of disassembly in his shop. I thought I was going to have crack at one of those, but nope. I had my choice of the pile in the back. It was pretty disappointing.
1974 CB350F
2013 VFR1200F
« Reply #23 on: May 17, 2013, 11:35:17 AM »
just between you and me, he is near impossible to buy from. Inflated prices, parts are in poor condition. He is very nice but not realistic on the prices. I had an opportunity a few years back to buy all of his cb750 stuff but he was motivated to sell due to pressure from the city to clean up his property. I guess they have slacked off for now but if they came back he would likely be motivated to sell again. Its a shame all of the stuff he has rotting outside and wont sell it.
Offline acollin
« Reply #24 on: May 17, 2013, 01:56:28 PM »
Maybe in California they'll pay anything. About a year ago I got a complete motor ---the guy claimed 13 k for $100-- no carbs, but it checked out sound. It s still sitting in my shop. I bought it to learn on and use it like a text book. Any procedure I plan to do on my driver, I'll often do on the spare motor first.
Andrew
Oregon
