Author Topic: LOCATION OF BUZZER?  (Read 2100 times)
Offline wapete
LOCATION OF BUZZER?
« on: May 19, 2013, 01:53:31 AM »
Can anyone tell me where the Buzzer that sounds when the indicators are on is located on a 1978 Hondamatic?
Its dam annoying and I would like to disconnect it
WA Pete
CB750A
CX500z
CB400T
CB350F
Offline LesterPiglet
  • 1977 CB550F2
Re: LOCATION OF BUZZER?
« Reply #1 on: May 19, 2013, 03:52:14 AM »
If it's the same as the other CB's it's attached to the left fork ear..in beside the headlight.
Offline salukispeed
« Reply #2 on: May 19, 2013, 08:47:51 AM »
It is on the inside of the left fork ear between the ear and headlight. The wires go into the head light bucketand it can be disconnected easily by taking out the headlight and tugging on the wires to see where they go. I believe the wires to it are black and blue/yellow, or blue/orange. You will also lose the alarm if the parking brake is set.
1974 CB750 K4
1970 CT70
1966 CA77 (305 Dream)
1984 GL1200 Interstate
1977 750A
1972 CL100
Offline wapete
« Reply #3 on: May 20, 2013, 02:50:48 AM »
Thank you for your responses.  I have already checked the headlight locations you suggest and there is not a buzzer there.  I have had another check today and the buzzer seems to be coming from somewhere around the battery. I have now found it, the buzzing is coming from the flasher unit - it has a buzzer built into the flasher. It still annoys me so I have wrapped it in some wadding to reduce the volume to a squeek.
Thanks for your input.
WA Pete
CB750A
CX500z
CB400T
CB350F
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #4 on: May 20, 2013, 06:12:50 AM »
Then . . . you have a non-standard flasher unit.
If you don't like any noise at all, you can just replace it with another standard flasher unit.  You can use a "normal" two-prong unit from the auto parts store.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline wapete
« Reply #5 on: May 20, 2013, 06:19:16 PM »
Thanks for your response.
WA Pete
CB750A
CX500z
CB400T
CB350F
