SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Installing Cylinder Sleeve O-Rings
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Installing Cylinder Sleeve O-Rings (Read 486 times)
Joewago
Full Member
1979 CB650
on:
April 12, 2019, 04:41:08 PM »
Is there some kinda trick to installing these things? 79 650. Gasket kit is from David Silver. The size is right as far as I can tell but once I push the ring in it expands and I'm left with a little dingle hanging out.
Logged
seanbarney41
not really that much younger than an
Really Old Timer ...
Re: Installing Cylinder Sleeve O-Rings
Reply #1 on:
April 12, 2019, 04:57:38 PM »
try lubeing em up with some dielectric/silicone grease
Logged
DaveBarbier
Reply #2 on:
April 13, 2019, 04:41:03 AM »
They do look thicker than normal. They should be tight enough where they should have to be “rolled” down the sleeve and pushed into place. I remember mine expanding and getting a little dingle but I just evened it out across the entire o-ring.
Aftermarket o-rings many times aren’t correctly sized but will just about work.
Logged
Patina Hyena - 550/650 674cc Hybrid Cafe Build
The Mayor - ‘79 CB650 Factory Revive
Need a full oil pump o-ring kit for your 650?
Want to use a Dyna S ignition on your 650?
Joewago
Full Member
1979 CB650
Reply #3 on:
April 15, 2019, 05:17:53 PM »
In case anyone is reading this later, the trick is to install them evenly like Dave said. If the ring is a clock, push in 12, 3, 6, and 9, then 2, 5, 8, 11, etc. Then smooth the remaining bumps. I used a shepherds crook dental pick.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
