Hey guys,
I'm trying to troubleshoot an issue that just started with my 1975 CB750 and I wanted to see if anybody had ideas on what might be the problem. After starting the bike up and riding it for a mile or so I'm seeing grey smoke come out of the far right cylinder where the spark plug goes in and possibly at the connection between the exhaust pipe and the engine. I've checked the spark plug here and both the area around the spark plug well and the plug itself are pretty fouled.
Here's a quick video that shows some of the smoke:
http://youtu.be/cV3hCZXZRIYIt also looks like I have an oil leak coming out of the engine between the two cylinders on the right side. I've attached a picture where this can (kind of) be seen. My guess is that this leaking oil is heating up and is causing the smoke after the engine gets hot.
Any thoughts on what might be causing this and where I should start? I've searched the clymers manual and I can't seem to find anything related. Should I check my compression? Do I need to replace the gaskets or is that not likely the issue? I'm willing to learn but at this point I've only done basic mechanical work. Thanks for the help!
Lars
