Author Topic: resurfacing Brake discs....  (Read 7770 times)
Offline Bru-tom
« on: May 22, 2013, 09:29:20 AM »
Hey people,
I was wondering what the best DIY method is to resurface brake discs? i have done quite a bit of machining in my time, but for some reason i dont think slapping it in the lathe and turning it down is going to work too well? i mean its stainless... I am no expert, so any advice and/or tips are welcome.
Thanks a ton
Offline greenjeans
  • 1972 CB750K2
Re: resurfacing Brake discs....
« Reply #1 on: May 22, 2013, 09:52:55 AM »
Are they warped ?  That would be the only time that I'd turn them.     I usually just hit them with some 60 grit on my sander followed by some brake cleaner.    No need for much more.
Offline Bru-tom
« Reply #2 on: May 22, 2013, 09:55:06 AM »
nope, just minor ridges...
What sander do you use?
« Reply #3 on: May 22, 2013, 09:56:34 AM »
A guy here turns them down to ?4mm??.
Offline Bru-tom
« Reply #4 on: May 22, 2013, 10:01:08 AM »
isnt 6mm the minimum?
I guess you would have to space the pads out?
« Reply #5 on: May 22, 2013, 10:06:58 AM »
I spin the disc in the lathe, and sand with a rubber block and emery cloth. I tried to turn one once, and it didn't work; too much tool chatter. To thin the discs they must be ground.
« Reply #6 on: May 22, 2013, 10:30:23 AM »
I got as far as trying to fit it in the lathe - lathe too small:)
Offline Supermex01
« Reply #7 on: May 22, 2013, 11:28:42 AM »
Best way to go:
Thomas Tokar
Truedisk LLC
truedisk.net (734) 625-0290
Afordable, safe and well done
Offline cavebear
« Reply #8 on: May 22, 2013, 11:29:37 AM »
I have mine blanchard ground. They look like new and even drilled discs can be surfaced this way.
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
Offline Supermex01
« Reply #9 on: May 22, 2013, 11:30:56 AM »
Best way to go:
Thomas Tokar
Truedisk LLC
PM me I'll tell you how to get a discount
Offline Bru-tom
« Reply #10 on: May 22, 2013, 11:41:52 AM »
thank you for your responses fellas.
Unfortunately, i am far away from any of the above-mentioned "companies".
i am looking for a DIY method. ;)
« Reply #11 on: May 22, 2013, 11:55:24 AM »
I scrabbed mine down with scotch bright and xylol just to make sure there is no brake fluid residue.  I believe it made a difference  and it was fairly easy.
Offline toytuff
  • "watching the pinheads"
« Reply #12 on: May 22, 2013, 01:14:12 PM »
Best way to go:
Thomas Tokar
Truedisk LLC
Yup, true disk. Great work.
tt
Offline mono
  • Definitely no
« Reply #13 on: May 22, 2013, 01:26:09 PM »
Best way to go:
Thomas Tokar
Truedisk LLC
awesome!  this guy is 30 mins north of me.
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #14 on: May 22, 2013, 08:02:24 PM »
I sanded mine with some 80 grit, I also had a fume hood to take all of the very nasty dust(possibly asepsis). Drilled, then used a paint stripper drum, chucked in a drill press at its highest speed. Check out my project if that helps. Also iron and air mag, gave a walk through of how to drill and re surface disks.
Auto Zone purchase, paint stripper.
Current ride: 78' Cb750F
Offline Bru-tom
« Reply #15 on: May 23, 2013, 11:38:50 AM »
how is that finish acquired?? its....B-E-A-UTIFUL!!!!!!!!
« Reply #16 on: May 23, 2013, 11:55:31 AM »
yep.  super service and killer product.
godfferys garage
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/
Offline wowbagger
  • Not much of an
« Reply #17 on: May 23, 2013, 11:58:39 AM »
« Reply #18 on: May 23, 2013, 12:02:12 PM »
I wonder if he grinds it or turns it?  Co bit was good enough for drilling, carbide should cut it IMHO.
Offline bjbuchanan
« Reply #19 on: May 23, 2013, 12:31:55 PM »
I'm pretty sure the stainless needs to be ground and at a slower rate so it doesn't get much heat put in to it. IIRC turning is a no go with them unless you want to just work harden the surface
« Reply #20 on: May 23, 2013, 12:43:57 PM »
hearing that Godfferys rotors are trusted on race bikes was good enough for me  :P
Offline bjbuchanan
« Reply #21 on: May 23, 2013, 12:47:16 PM »
Without a doubt I will be getting Goddfrey's stuff when I decide the direction I go in with the brake system
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #22 on: May 23, 2013, 02:47:40 PM »
Truedisk and Godfrey's stuff is top notch, no doubt.
Just wanted to throw this out there though.  If you don't want to ship it anywhere, just find a local auto parts store that does machine work and ask 'em if they grind flywheels.  If they can to that they most likely have resurfaced rotors before.
Had mine done at my local shop in NJ and they turned out pretty well.  About $30 a rotor, but being near NYC raises prices on everything.
Pic attached of a dual disc setup I just finished for someone.  (BONUS QUESTION - What's that towards the top between the rotors?? I have a few more for sale!).
Matt
« Reply #23 on: May 23, 2013, 04:52:54 PM »
that is a speedo drive adapter.  hope you didnt leave it out on a build  ::)
Offline mcuozzo
« Reply #24 on: May 24, 2013, 01:05:06 PM »
Nope, it was made for that setup! It's a dual disk speedo adapter.  Bought one from a member to upgrade my brakes.  Guy flew the coop.  On a another forum someone wanted dual disks, so I refurbished some calipers for him, drilled, resurfaced and pc'ed his rotors.  Had another adapter made for him.  While I was at it figured it would be best to have a few (6) made...will post them up for sale eventually.
Matt
