Author Topic: Signal Beeper  (Read 958 times)
rotortiller
Signal Beeper
« on: May 21, 2013, 05:09:12 PM »
Some guys like it some guys plain hate it. Some guys like it but hate how it speeds up and slows down (sometimes stops) with normal for type voltage fluctuations. I cracked the sucker open like a tach or speedo to see what makes it tick. It uses a spring voice coil with a matching resistor and is coupled to a steel diaphragm. Crude or Flintstone like as the rest of the bike,  I removed Rubble's guts. I had a piezo buzzer laying around from Radio Shack 86DB P/N 2730060 and shoved it in the hole after cutting the mounting tabs off, staked the Honda metal cover back on less the diaphragm then slid the rubber cover back on like a Ramzee, and Bobs my uncle. Wired it direct less the resistor at the soldered end of the buzzards harness. Works better than new and it still drives some of my riding buddies nuts, however it is a now a very consistent and reliable quality aggravation to them.
rt
Offline bjbuchanan
Re: Signal Beeper
« Reply #1 on: May 21, 2013, 05:37:39 PM »
Nice job it is always cool to improve stock
Re: Signal Beeper
« Reply #2 on: May 21, 2013, 06:37:01 PM »
ha ha..have been thinking about putting them all back on, so that all my riding buddies can enjoy it too ;D ;D ;D  They will enjoy it about the same amount as I enjoy their exhaust notes
Offline chewbacca5000
  • I polish covers!
Re: Signal Beeper
« Reply #3 on: May 25, 2013, 05:11:39 AM »
rt
You may be onto something here.  May you can custom design buz tones for the full effect.  Could be a whole new industry built around annoying your fellow riders.
Offline Vreihenmotor6
Re: Signal Beeper
« Reply #4 on: May 26, 2013, 09:31:33 AM »
I swapped the lights on buzzer in my old VW for Wagners Ride of the Valkyries
