Support the site. Your contributions keep this site running.
rear axle?you might have a 550 one?the end slots on the 500 with the open type slot is thicker than the later 550 closed type so the spacers were different,ill go measure for you.45mm.
If the front axle gets turned around it looks like it will never fit.
you got the nut the right way around?the hex head goes inboard,it has a shoulder inside,,i might have an axle and spacer,,ill go measure for you,,again!no worries,just send more beer!sorry mate i dont have one,cancel that beer.
Spacer length 17mm
