Author Topic: Painting a tank  (Read 7273 times)
Offline davidtime
Re: Painting a tank
« Reply #25 on: May 31, 2013, 08:37:59 AM »
So I found this site for the single stage spraymax 2k in colors and it runs the same price as the clear alone. It is base and clear in one can. I am sold on this color. I am curious if anyone has ever used the colored premixed 2k.
http://www.66autocolor.com/Spray_Max_Aerosol_White_Gold_Metallic_p/spm-pwl.htm
I dunno, it seems to defeats the purpose of the 2 stage's UV and chemical resistance. I would have to coat in the 2 stage clear anyway. Save some money and use premixed color laquer in a rattle can. I know a member did that here a couple of years ago and claimed an $18 dollar paint job but I would have to guess how long it lasted.
Can you use a more budget friendly lacquer and use the 2k clear over it and have it turn out good?
It turned out excellent! Laquer is easy to use and fine sand with 1500 grit wet/dry. As long as you have a good primer coat to hold to the metal. I think it was Kong thta suggests 2 part primer as well. Then the clear goes on over the color. I did a couple of coats of that. It sands well too then buff. I was stunned and amazed that I did such a nice paint job. And its 2 years old and still looks like new. Of course I put the bike in a garage for the winter and use a cover always.
I'm going to be using 2 colors for the tank and the seat cowl so it should be interesting. I have never done 2 colors before but to say I did my own graphics will be worth it. I don't want my first time to be done with $20 a can paint because that could get expensive.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Painting a tank
« Reply #26 on: May 31, 2013, 08:42:22 AM »
That would be me Duanoob and it wasn't lacquer, it was the same urethane based automotive grade 2k paint as the clear . Alotta people clear over a spray bomb(enamel) and it works fine however its like laying a cement foundation over a wooden deck. Ever see those shaolin monks demonstrations ( or karate kid 2) where they bust the ice blocks on top and below . Point is it is the weakest link and it isn't as tough at all as using the old paint finish as a base.  You can call 66autocolor  and they will add any color code from any vehicle you want into the can . I have done some paint jobs no one would believe from those preloaded cans . Here is my thread on the 18$ paint job. Check it out for yourself and yes it looks just as good today as ever.
http://forums.sohc4.net/index.php?topic=98350.0
BTW here is a blog from 66autocolor where you can see another sohc'er did a sweet job on a cb550 SS. The RD350 tank is my handywork!
http://www.66autocolor.blogspot.com/
I had an old tank that I buffed a spot and use a paint camera at a local body shop. Came up from there data base as Boeing 747 Orange!
About to do a cb750 tank in a Honda Civic Sapphire Metallic Blue complete with the decals from the planet blue era. I find myself looking at cars a lot more now just for the colors I like . All you need is a make and model to look up and you can get it in a can . I badly want to do a Toyota Corolla Spruce Mica Green eventually. Painting is fun and gratifying .Let the world be your crayon box. Also I have no affiliation with 66autocolor, I am just your average married guy with a 9-5 and a love for projects big and small.
That's fine dude, nice job and all. But I'm still not buying your $18 paint job. It cost me $29 from 66 just to have colored spramax delivered to me. Then you don't include primer, sand paper, buff pads, polishing compounds, decals/ striping, cleaning compounds, paint removers, de-rusting products, etc, etc, etc.
Unless you work in or own a paint shop, it just a bit misleading that's all. The average backyard sohc4 owner like myself has to buy all that stuff and it adds up to a lot more than $18, that's all.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline 78whiteorbs
Re: Painting a tank
« Reply #27 on: May 31, 2013, 08:43:42 AM »
Davidtime- yes all in one can. It senseless to use any other type of paint than urethane. 2k which is automotive grade( not meant for model cars and such) especially when you can get it in any color and there is no buffing. And its all in one stage so takes less time. Really a no brainer in my book. You can you use whatever you like and with the proper technic and care. Get great results but how long they last is based on how good the substance is. Get it 2k in a can and be done with it. Paint it in one step and admire the results everytime you look at your bike. That's been my routine.
Offline 78whiteorbs
Re: Painting a tank
« Reply #28 on: May 31, 2013, 09:05:45 AM »
Duanob- pretty sure I addressed your skepticism in my thread. Perhaps you should read it again. I didn't. Use any of the forementioned items- it was single stage.. Aside from sanding the surface. With some 3-400 grit I didn't use any other materials. If you don't like the title of my thread feel free not to post your cricisms. Contribute something meaningful I tead of criticizing someone elses job. Its just not needed.  The only reason I posted in this thread was to correct you were you in the fact that I used urethane single stage 2k paint with the color mixed in NOT what you stated. I am not a rich man and if I find a way to save a buck I like to pass on
Re: Painting a tank
« Reply #29 on: May 31, 2013, 11:47:05 AM »
The SprayMax 2K is a urethane clear which is nearly impervious to fuel staining and damage. The Spraymax 1K is not a urethane but is a single part premixed paint like a conventional spray bomb. The difference is the superior spray pattern provided by the nozzle and the good quality paint being used.
If the underlying paint/primer is properly cured the SprayMax 2K is compatible with most paints.  3 coats gives a very nice finish. Once activated you will need to use the SprayMax 2K can within about 24 hours for best results.
As with most finishes, the first coat of the clear being misted on tends to be a safe method of application so the subsequent coats can be applied safely. A wet first coat could put too much solvent on the previous color coat causing it to react if the SprayMax 2K solvents in the clear would normally attack it.
Offline davidtime
Re: Painting a tank
« Reply #30 on: May 31, 2013, 02:53:16 PM »
This one here shows to be clear, base and hardener all in one. The 1k needs the clear. This one has the 2k paint material in it.
http://www.66autocolor.com/SprayMax_2K_Aerosol_Auto_Paint_by_U_S_Chemical_p/spm-mix2k.htm
