Hey guys,
In the process of rebuilding (or more accurately just cleaning and servicing) the carbs on my '74 CB550.
After quite a bit of reading here and inspecting my carbs I decided to re-use all of the original jets and needle, etc. I ordered a gasket / o-ring set from ServiceHonda Part # 16010-323-315 for the 022A Carbs and began reassembly. Everything wen't smoothly until I arrived at the float bowl o-ring (the main reason for purchasing the kits, as mine had been pinched by the PO and were torn and unusable. Unfortunately, no matter how many times I question my own abilities, I end up concluding that the damned o-rings are just too big. As I place a finger in each of the corners of the float bowl seat, careful not to pull the gasket around and stretch it, I still end up with excess material that won't settle into the seat. Edit: Ironically the opposite issue that I have when trying to re-install the old gaskets, which are just a bit too small to remain in the seat while I try to assemble it!
I'm not sure if there's a process (like boiling?) that might shrink them a bit, but before I go down that road I'm just curious if anyone has had this issue before. I've called ServiceHonda and cross referenced all of the part numbers again and everything seems correct. I also measured the O-ring, and while I'm not sure how accurate I was it appears to be roughly 73mm, but I can't find a reference for how large its supposed to be.
Thanks for reading!
