Author Topic: Headline: Hondaman rebuilds his old friend - FOUND GOOD OIL!  (Read 131686 times)
Re: Headline: Hondaman gives in and rebuilds his old friend!
« Reply #300 on: October 21, 2013, 03:33:06 PM »
OK fine, never mind then.....  ;)
Mark, when you firing her up? Maybe we could time it and go for a cold-ass ride?!  ;)
« Reply #301 on: October 21, 2013, 06:05:22 PM »
Jerry, it would be interesting if you could shoe horn a 900cc kit in a 550, as it is you can get some thin liners with the Gentleman's Express or Henry Abe pistons in a 550 cylinder.  I appreciate the information, and the assistance this will provide other 750 owners if they glean through HondaMan's threads.
Mark, unless you sold them, I think you have a set of old 750 std pistons you are holding for me if I can get the money to put them to use. The HA kit would be less money I think. Only Soos has modified a set here and offered it to others, a few others have tried to build one but they disappear before finished or quit documenting...  There is a current GE build thread going on...
People don't understand the mods or don't provide machinist with the drawings. I have the article and understand the mods, the valve relief pockets require another trip to machinist or good drill press or mill access tilt table/rotating head with appropriate cutters.
David
P.S. Mark, you can kill this post when you clean up the side conversations, wanted to publically acknowledge Jerry's contribution as he's one of the pillars of the SOHC/4 forums I think.  Thanks publically is deserved for all the high volume contributors who know what they are talking about...and provide factual information.
« Reply #302 on: October 21, 2013, 08:35:35 PM »
I'd love a cold-ass ride, if I can get it back together? My day job keeps getting in the way. I just got home, now.
I got to spend a little time on it this weekend: got the 4 'repro' pipes all shined up again. They are only 4 years old, I think, and already seem seedy. At least they are 4! If I get some $ together and find one, I need a 'real' Honda #2 pipe, at least.
Next is to install the pipes, and at this point I may reassemble the tank and top stuff, except I would like to pull & paint the battery box. It looks a little gritty, is probably rusty under the sides. I will paint it sometime before Spring, but as it is already snowing and I have 2 business trips coming up, gotta at least get it to an assembled state so it doesn't sit on the patio all winter.
« Reply #303 on: October 21, 2013, 10:18:11 PM »
My bike is ready, it's the engine thing  ::)  I put the bottom end together today. Greens on the outside and black in the middle where the main damage occurred. Plastigauge says .038 - .050mm all across. Little looser than before but I can live with that. Taking a look at the top end tomorrow. May have an issue with the oil ring I just got from Total Seal. I gapped the rails so they are good but installing them with the expander doesn't look right. Sticking out too far and the rail gap is much larger. The Total Seal info says "Do not attempt to modify the expander in any way". Gotta compare it to the other previous 4 and give them a call. It may have an inner 'shoulder' and the others don't but I won't know until I dig in. But hey, springtime is right around the cold corner.....  ;)
« Reply #304 on: October 22, 2013, 11:00:57 PM »
I'm chafing at the bit to ride: I may end up breaking it in behind the Vetter lowers, in 10 degree weather!
« Reply #305 on: October 22, 2013, 11:53:36 PM »
I picked up a set of camo Carhart like bibs from ebay seller Shelton's Clothing with intent to handle cold weather riding with intent of aunt who is seamstress and loves sewing quilts and embroidery to put a urethane coated ripstop nylon outer cover (think...like a rain suit)  to cut the wind and provide modest wet protection. Naturally I would owe her big time...as well as some money for time. Tent seam sealer then used on sewn areas to slow water ingress, or paint with polyurethane.  Find some 3M reflective fabric and you could hide the side seam and polyurethane coating with that stripe.
Yeah I think too much...
I have some Volvo 240 seat heater grids of resistive wire that were thermo controlled to operate below 59 degrees, thermo  change could change that... then use small gel cell with battery voltage monitor so you don't kill it.
Offline MoMo
  • Ride like you're invisible
« Reply #306 on: October 23, 2013, 06:03:25 PM »
David,  hw cold does it get where you are in Tenn?   ...Larry
« Reply #307 on: October 23, 2013, 08:06:50 PM »
I once rode my trusty 750 from Macomb, IL to Chicago in February (my car was down at the time) for an important something-or-'nuther event. It never got above 12 degrees on the way up. A day later, I had to ride back in the dark, even colder, with snow squalls and that IL humidity. After that trip, I don't think I've ever really been COLD again...at least I had the Vetter!
Offline Tews19
  • I am no
« Reply #308 on: October 23, 2013, 08:15:17 PM »
I read this thread every time I get the email notifying me of an update.. Great work as usual Mark..... Coldest I rode was 28 degrees with a wind chill of "freeze yo nutz off"...... Never again....
« Last Edit: October 23, 2013, 08:54:44 PM by Tews19 »
1970 Honda CB750 survivor.
« Reply #309 on: October 23, 2013, 08:29:08 PM »
Personally, I think something DID freeze off on that IL trip: it left me the way I am now...  :o
I once rode across part of CO during a sub-zero winter's day, but here in the dry West it just isn't like that IL trip. IIRC, the whole night ride back was below 0 degrees (F). I still remember stopping at a restaurant about 100 miles into it to get some pie & coffee: when I pulled up, I couldn't get my left leg down and the bike fell to the peg before I caught it. At least that adrenalin rush warmed me up enough to get into the restaurant! I also remember putting my hand on the oil tank to check as I was going in: it was stone cold. Hope I NEVER have to do that again!
Gotta go find my weekend pipe pics. They look real pretty now! :D
« Reply #310 on: October 25, 2013, 02:33:43 PM »
Volvo had an insulated jacket to put thebattery in as an accessory item. It was a foil faced insulated blanketthat retained battery heat from operation. Used to keep the battery from freezing and exploding as they can do if there is too much water in the battery in sub zero temps. I ran a block heater on my '66 Volvo with dual SUs as it was not liking sub zero starting. It made such a difference and was very handy. Warm ups were nearly instantly and starting effortless. The Weber DGV was a nasty carb that came on it when I bought it in '94 and it was improperly jetted with no power.
« Reply #311 on: November 08, 2013, 09:56:51 PM »
Now for a trick item, long been up my sleeve...the LED Timing Light for the Transistor Ignition.
I'm not sure I have a good way for others to install this, just yet. The pix below will show why: this first version requires drilling a 1/4" (6mm for you metric guys) hole in the point plate, just above the L set of points. This is for the switch that will select LEFT or RIGHT points. It is spring loaded, returns itself to center. Next to this hole a dimple is needed to lock the aligning washer in place, which keeps the switch from rotating: there is a dimple-tang locating washer with these switches to make this happen. The LED and circuit parts are small, but it's pretty bright in the dark cavity behind the points plate on the bike, yet the LED lens on the end needs to point at the TDC marker in the 'dark side' by the spark advancer. I'll make more pix of the installation on the bike tomorrow.
There is a Blue and a Yellow wire from the switch that attaches to the points along with the normal wires, match up the colors and you're done. Make sure the wires are routed away from anything that moves...
« Reply #312 on: November 08, 2013, 10:03:23 PM »
The 'other versions' of this included the too-expensive (but REALLY bright!) LED striplite prototype. I like that one and may end up using it so I can see it outdoors on a Colorado summer day at 6000 feet. There was also the single LED version of that one. Both have a metal strip (here made from plumber's tape for practice) that clips onto the point plate and one of the screws. It's a tight fit under the timing cover, though, and really ugly. In this picture, it slipped away from the top mounting screw's hole as I snapped: the timing hole is almost fully open when the bracket is properly located. The bracket would have to be a punched-out custom sheet metal part, mighty expensive to make.
« Reply #313 on: November 09, 2013, 02:08:31 AM »
Certainly clever but isn't it easier to use timing light, how often do you check timing anyway?
Offline Kickstart
« Reply #314 on: November 09, 2013, 06:39:04 PM »
Interesting... I thought of building the same thing after making my own LED light with some alligator clips to help me set the timing.  A built in unit that was always on, coupled with a clear cover could have a cool looking effect.
Couldn't you purchase some surface mount leds and somehow attach them to the back side of the timing plate (epoxy?).  A few of them around the hole on the back of the plate should do nicely.
I'm not sure if I like the spring loaded switch.  I think I'd prefer the locking type so I'd have my hands free to focus on adjusting the timing plate.
How would this effect the accuracy of setting the time vs. using a timing gun?  I assume it's effectively the same, but I figure the timing gun would be slightly slower (probably not enough to make a difference?)
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
« Reply #315 on: November 09, 2013, 10:02:39 PM »
The LEDs are about 250 times faster (ON time measured in nanoseconds vs. milliseconds for a strobe fire circuit) than a timing light, so in that regard it will work fine. The reason for the spring switch is the limited current available to the LED at speeds over 3500 RPM: it gets real dim then. My Transistor Ignition limits the power to the points to 120mA, and these ultra-brite LEDs use about 60mA in a flash. So, if the engine is revved up beyond about 3500 RPM with the switch held ON, the spark can become pretty weak, and the first thing that goes 'out' is the LED.
The intent of the gadget is to simply and easily check the timing. The points don't wear anywhere nearly as much as some folks argued they would (if you can find the thread back in 2006 when we developed this thing here, you'll see the opinions), which I knew would not happen - from past experience with it. So, I started to make this gizmo way back when, but the expense of making a mount for it is almost 12x as much as the parts(!). That's why I haven't brought it out as a 'product' so far.
Since the anticipated wear factor was to be the points foot rubbing wear, the check can consist of simply flicking on the switch for the desired side at idle or full advance, and taking a peek to make sure it's on the marks. It's that fast. Thing is: in the 6+ years I've had mine running, the timing hasn't moved, period. The gap never changed and the foot didn't wear, because there is no arcing. It's the arc/weld/break-open cycle that makes them wear out, both at the tungsten and the pivot: without the arc, there is no weld, and since they are designed to take that abuse but don't see it now, there just isn't any wear, either.
I found that I can make all the parts available for about $15, until it gets to the bracket. That thing costs about $10 each to have made, plus a setup CNC charge of $400 at a sheet metal shop. I don't think there is much 'value' in a $35 LED timing light that will show the points never shifted in timing, hence my reluctance to bring it out. I sure have a lot of parts from before the 'reality check' though!
For the folks who want 'glitz' it is easy to nab some from the back-blast of the coils. We used to hook up neon bulbs to the points, much like the old Maxi-Dwell units, to show a flicker while running, then hooked them to the forward downtubes for a night light show. There even used to be a circle of 8 neon bulbs in the tach console of the Shelby GT500 Mustang console that picked up their trigger from the individual sparkplug fires on those monster 650+ HP Cobra FE 428 engines (one of my college buddies had this arrangement in his GT500KR). In 1969, that was COOL!
Offline Kickstart
« Reply #316 on: November 09, 2013, 10:30:26 PM »
ah... I see.
Maybe you could move everything except for the LEDs outside of the points compartment by running a few wires back and forth.  Leave it up to the owner to install the switch somewhere convenient (under the seat, or near the brake light switch, etc.) and then you don't need the bracket, you just need to worry about installing the LEDs - which should be easy with some thin metal.
You could add a couple transistors or op-amp to solve higher-rpm issue (powered by a nearby source - again under seat or near brake light).  You could also offer a version of the Hondaman Ignition with some extra wires to power the LEDs that are always bright regardless of RPM.
- Chris
« Reply #317 on: November 09, 2013, 10:53:05 PM »
ah... I see.
I thought of many of those things, too. But, the idea behind this gadget is an inexpensive transistor 'booster' box that matches the genre and reliability of the Four (although now it's also on hundreds of Twins, Singles, outboard motors, old cars, tractors, etc., all over the globe). Those add-ons also start to make it hard for the non-electrical folks to install: so far it hasn't been too bad trying to explain to most of those riders how to hook it up, and it works for them. That has turned out to be at least half the success (or not) of these things. I'm not much of a marketer, just like to work with the vintage crowd (like me?). I have a hard time keeping up with making them during the Spring season!
« Reply #318 on: November 13, 2013, 05:26:09 AM »
David, how cold does it get in Tn where you are?
REPLY >>>> (NOOK grrr cant get below quote, nothing a little html retyping wont fix...)
In foothills of Appalachain Mountains here in NE TN @ 1500 ft and we see winter with average temps in 40s during Dec w/Jan & Feb being nasty cold with most snow/ice then. Historically speaking, about 16" of snow a year but had over 38" last year. Temps are similar to Columbus Ohio with it being about 5 degrees warmer with less snow. Sierra Vista (AZ) was cold but not much snow in town usually, but it was at 5k ft and dry desert air is different than moist cold here in TN as I grew up here and lived here until after college when I worked for TRW, Resistive Prod. Div. in Newland, NC and lived in Boone, NC. It was in mountains of NW NC and had lots of snow (3300 ft)
It gets sub zere here often for a week at a time. Mountains and hills are colder than piedmont or open terrain relative to latitude. Gotta be in GA to be nice in winter.
>>> original message quote>>>>>
[/quote]
[/quote]
« Last Edit: November 13, 2013, 05:35:57 AM by RAFster122S »
Offline jojo
« Reply #319 on: November 24, 2013, 05:35:12 PM »
Mark:
I'm unclear on where these o-rings go. Are these only for K0 thru K2/3?
These are  my measurements from new Cycle-x rubbers.
The oil jets are 1.9 x 5.9
The oil pucks are 2.8 x 26
That leaves the sleeves over the head studs 1.9thick x 8.3high x 14.2od
Course this is a K6 head and I'm using the dowels too.
Hope this isn't a dumb question.
Thanks
Steve
These are the 2 in the center rear of the cylinders, which feed the oil to the head. They are the 2 recessed ones nearest the cam tunnel, at the back.
anyway you can post a pic of the 2 recessed ones?
« Reply #320 on: November 24, 2013, 08:45:36 PM »
Mark:
Thanks
Steve
« Reply #321 on: November 24, 2013, 09:04:21 PM »
So, I finally decided to build me a custom Transistor Ignition. It's in a blue-green anodized box, which I hope to match the tank and side covers to over this winter! I've always wanted the Blue-Green K0 color, never could get one...
The Ignition has the Security Switch added to it. I mounted it to a 45-degree, offset bracket onto the bottom of the battery box so I can reach it just underneath the left side cover when installed on the bike. (If you have a pre-1976 750, this area is open: after that, it is full of stuff that made the DOT/EPA group happier...) The box had to be offset toward the front to clear both the plastic rear fender(let) and the oil tank's breather line to the back of the engine. As long as I was there, I made a new line...
Next I have to clean up the old "extra-fuse" setup I was carrying up above there, tied on with a Velcro strap. Ugly...
« Reply #322 on: November 24, 2013, 09:06:04 PM »
Hmmm...also discovered the rectifier's connector had melted plastic and corroded contacts, replaced that, too...
« Reply #323 on: November 24, 2013, 09:10:12 PM »
I tried and tried and tired and tried....then had supper and tried twice more...the oil PSI would not come up! The pump is primed, but the temperature was mighty cold today and the oil is 15w40 Diesel for the startup. The bearings in the engine all have moly smeared in them, makes cranking speed real slow, poor starter. Good thing I just installed new brushes, it needed the help!
So, I set my trusty infrared heater next to the oil tank and oil lines for an hour, on HI. Came back out and hit the starter, and in 2 seconds had full oil pressure! It was stuck in those old hoses...
« Reply #324 on: November 24, 2013, 09:35:43 PM »
Hondaman, i think those brackets could be knocked out on waterjet or plasma or laser, far cheaper than you were quoted..
 How far was that winter ride ?
