Author Topic: Headline: Hondaman rebuilds his old friend - FOUND GOOD OIL!  (Read 127895 times)
Offline goldarrow
  • one day, i'll be an
« Reply #375 on: September 26, 2014, 08:26:36 PM »
Come on people.  I know I'm not all that smart but come on
26.99745454 dollars per gallon, and you have to buy at 55 gallon quantity
vs.
 25.95 for 4L deal
You guys go figure
CB550 K0
Offline oldhatt45
Re: Headline: Hondaman rebuilds his old friend - FOUND GOOD OIL!
« Reply #376 on: September 27, 2014, 10:54:01 AM »
Sorry I'm late to the party regarding the Oil Type.
From my original 1976 version notebook, I just checked and from brand new, I was running Bel-Ray 20w-40 in my old girl.  Never used anything else.  Very glad to hear that the newer Bel-Ray performs well in these Old Ladies.
Thank You Hondaman for the Info.  Also the info regarding the Zinc additive!
Charlie
Offline willis
  • 1974 CB750
« Reply #377 on: November 11, 2014, 07:48:48 AM »
I was looking at getting some of the Bel-Ray mineral oil per Hondaman's glowing recommendation when I ran across the post on the other side of the internet...
http://hondachopper.yuku.com/topic/51000/Re-Bel-Ray-20W50-4-stroke-mineral-oil-bad-for-the-clutch?page=-1#.VGIuwfnF-FU
Obviously it could have been other issues, but it made me hesitate just a tad...
« Last Edit: November 11, 2014, 07:52:29 AM by willis »
Offline ofreen
« Reply #378 on: November 11, 2014, 08:16:34 AM »
So, now we know which oil is best!
I know a guy who has a '75F that will turn over 149,000 original miles next week (if the weather holds).  He has been using Spectro conventional oil in it since 62,000 miles. He hasn't found the need for any zinc additives with the Spectro. ;)
Greg
'75 CB750F
« Reply #379 on: November 11, 2014, 08:40:26 AM »
You (or that guy you know) are the man!
Just curious does the Spectro stipulate it is MC oil?
Offline ofreen
« Reply #380 on: November 11, 2014, 09:27:08 AM »
Yes, it is termed motorcycle oil.  Here is what the label looks like these days.
Greg
'75 CB750F
« Reply #381 on: November 11, 2014, 09:35:59 AM »
I've always heard good stuff about Spectro, never tried it myself.
Offline Roach Carver
« Reply #382 on: November 11, 2014, 01:26:36 PM »
didn't it used to be golden spectro
« Reply #383 on: November 11, 2014, 01:46:34 PM »
Golden Spectro is their full synthetic;I've ran 10/40 standard Spectro in customers bikes in the past and it shifted great for the whole oil change duration.
Online HondaMan
« Reply #384 on: November 11, 2014, 07:28:37 PM »
What's that stuff cost, Greg? I've not seen that, only their "Golden" kind before. The way synthetics seem to find their way out of the paper gaskets in these engines, I tend to shy away from them despite their good performance.
Offline ofreen
« Reply #385 on: November 12, 2014, 05:03:17 AM »
Good morning, Mark. It ain't cheap, about 8 bucks a quart these days.  Sometimes the liter size is on the shelf for the same price.  But I never change it before 3000 miles, with a filter change every other change.
From Spectro's FAQ page on their heavy duty oils -
What is the zinc content, if any in your HD motorcycle oil SAE 50?
Answer:
All of our HD oils (HD20w50, HD25w60, HD50, HD60, HD70) contain 1800ppm zinc (zddp) and phosphorus.
http://www.spectro-oils.com/technical-data/faq/
Greg
'75 CB750F
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #386 on: November 13, 2014, 06:41:46 PM »
I may be opening a can of worms here..but...
What's the deal with using such viscous oil? Why 20w50 in a fresh rebuild?  Why not 5w40 or 10w40?
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
« Reply #387 on: November 13, 2014, 06:54:02 PM »
Harley V-twins take heavier viscosity oil than our Honda sohc's
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #388 on: November 13, 2014, 07:04:37 PM »
?  That doesn't answer my question. HM is using 20w50 in a fresh rebuild on his SOHC. I'm curious why such a heavy oil in a fresh tight engine when lighter weights would seem to me to give adequate protection and tax the oil pump less, in theory.
The Bel-Ray you bought and used also comes in a 10w40. I'd be tempted personally to use that. 20w50 is going to starve for longer periods of time on startup, for one thing.
I'm not here to make any judgments, I'm really just curious.
Offline ofreen
« Reply #389 on: November 13, 2014, 07:39:54 PM »
Are you sure about that? ;)
Greg
'75 CB750F
Online HondaMan
« Reply #390 on: November 13, 2014, 09:33:53 PM »
Hmm...this sounds a little like inexperience? First thing: Honda's recommendation is 20w50 above 50 degrees F (ambient air) operation, and/or for touring use: check any of the OEM Honda manuals and you will find this spec. They consider commuting on freeways as touring use, too.
In 1973 there was a major boo-boo in the Jinglish translation of the Owner's Manuals that came on the 750 and 550 Fours that did not get 'caught' until the 750F2 came out: it resulted in the mis-translation that became, generically, "use 10w40 oil". This "absolute minimum spec" (that was Honda's stated intent) was also cast onto the oil dipsticks of the 500/550 engines (and many Twins of the era) as Honda's last-stop-hope to prevent riders from using straight 30w or lighter oils. What it MEANT to say, in proper Japanese, was, "[never] use LESS than 10w40 oil". Those of us who, by then, had many tens of thousands of miles on our Fours knew this for the error it was: today most of that tribal knowledge is gone, and the later incarnations of motorcycles with water-cooled cylinders, fuel injection to control engine temps, and better metal alloys have made the later bikes all happy with the lighter oils (and confused newer riders who are just now coming to these older bikes). Your 1960s-designed Four needs 20w50 oil unless you never run over 50 MPH and/or have an oil cooler: then it might survive both with 20w40 oil. For example: I have seen engines from the East Coast (US) with 30k miles on them that barely needed new rings, and those mostly from sitting the last 20+ years: the reason is because the owners live in areas where the highest speed limit is 55 MPH, even today. Those bikes seldom, if ever, needed the protection of the 50w at high engine temps, as the engines never got that loaded. Many used 20w40 oils from Bel-Ray, Castrol, Valvoline, or Havoline with acceptable results, except where their valve guides wore too much and made the engine leak or burn oil. Those who used 20w50 oils fared far better.
Here in the West, I ride 80-90MPH every time I hit the interstate, lest I be run over from behind. When I had my shop, it was in rural Illinois near Missouri, and we seldom rode less than 65 MPH on any road. Between there and here (in Colorado) there is nothing but open roads and high speeds, so anything less than 20w50 will cause issues of oil breakdown in these engines, quickly (i.e., with petroleum-based oils). Modern synthetics do have longer chain molecules that can abide in these temperatures, but that's a different topic and one left for engineering and experimentation to fit to these engines: what we know from experience is that 10w40 petroleum is too light for these engines in summertime. I used to use the old Castrol GTX{L series} motorcycle oils in the 1970s in 10w50 for winter riding (so it would start easier), but that's the only time it worked OK.
As for the startup: if your oil pump's check valve works as it should, chances are the oil light will extinguish well before the engine starts (electric start) or at the end of the first kick (kick starter), anyway. If it doesn't do this, then the check valve is leaking the oil back from the oil galley through the oil filter, and this needs to be fixed. It means you're losing flow and pressure when running, too. The oil galleys to the head stay full all the time, so as soon as the kickstart gear moves, it is a solid fluid column all the way to the cam bearing squirt. When I rebuild engines I connect them to an oil tank and spin it until it fills these galleys, monitoring the progress by leaving the cam cover off as the last assembly step (yep, it can make a mess...). Once full, turning even the big crankshaft nut by the points (with a wrench) by hand will make oil drool out the cam bearings.
Online HondaMan
« Reply #391 on: November 13, 2014, 09:44:12 PM »
Answer:
I noticed their higher zinc content last Fall when I was cruising their site for info: that's a lot better than many other oils out there. I didn't realize those were synthetics when I was looking at them, though. Pretty cool! I'll go look around here for some of that when my next change comes up on my F1 bike. I'm REAL happy now with the EXL feeling like good ol' XLR in my K2 now, it feels so much like "the old days" that I am reveling in that after almost 10 years of lousy oils. It's been a blast to start to kick it and have it running before the kick lever is halfway down, just like the "old days" used to be. It's been troubled solely by the 'new' oils since I woke it back up in 2005 after the cancer-caused "time out" of 5 years. Now I am 100% sure of that.
Here's a thought: you've mentioned a come-and-go oil leak (or weep) on your "F" before. Could it be caused by the synthetic? I know that was a problem with the two I have when I ran the Mobil1 (diesel formulation). On the K2, it stopped the weeping almost everywhere when I switched away from synthetic to petroleum again (except the cam cover gasket). On the "F" it still leaks around the head gasket, now with petro oils.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #392 on: November 14, 2014, 05:41:32 AM »
Oh for sure. I know oils pretty well but this being my first go round with any sort of motorcycle, my inexperience lies in the realm of motorcycles rather than oil. I likened this motor to my Corvair engine since that is my experience in air cooled motors, and 20w50 would have starved the heads for several seconds on startup, but then that engine had pushrods where the sohc engines do not. Big difference now that I think about it.
I see we have a local dealer with the full line of Bel-Ray oils, as well as several other popular brands.
Anyone tried the Mobil 1 racing 4T in their bike?
Sent from my personal electronic device using a program application
Offline mihai.i
  • Sorry for my english!
« Reply #393 on: November 14, 2014, 06:22:43 AM »
Honda Cb550k 1978
Offline ofreen
« Reply #394 on: November 14, 2014, 11:32:13 AM »
The Spectro oil I am using is a conventional or 'mineral' oil.  I agree with you about synthetics and leaks with an old engine's gaskets and seals.  We had a discussion about it on the highest mileage thread a while back.  Found it -
http://forums.sohc4.net/index.php?topic=6895.msg1022043#msg1022043
See the link above for my experience with Mobil 1 4T in the 750.  I use Mobil 1 in my '90 CBR1000F with excellent results.
Greg
'75 CB750F
« Reply #395 on: November 14, 2014, 04:33:14 PM »
The Spectro oil I am using ...
That guy is a legend, Spectro oil must be the best.
Offline ofreen
« Reply #396 on: November 14, 2014, 05:36:24 PM »
I don't know about the guy, but the bike impresses the hell out of me. ;)
Greg
'75 CB750F
« Reply #397 on: November 14, 2014, 06:01:37 PM »
Anyone tried Motul Classic Car line?
http://motul.speclube.com/products/all-products/classic-oil-20w50-2l/
Mihai, Motul is not that easy to find in USA - probably nobody tried it.
Offline edwardmorris
  • Youngish
« Reply #398 on: November 14, 2014, 07:48:34 PM »
Not sure if its the same but I think Gordon uses Motul 7100 10W-40, and had some good things to say about it.
Online HondaMan
« Reply #399 on: November 14, 2014, 08:02:34 PM »
Now, THERE's a good idea! It meets the old SF/CC spec, which is precisely what Honda calls for in the k2 and later 750, and the 1973 and later 550/350F/400F manuals. It has anti-foaming additives, plating additives (aka ZDDP), and an anti-oxidant (the "CC" spec) just like the older oils from Valvoline, Havoline, Castrol, and a few others that worked well.
It was the notorious (and short-lived) "SH" spec when things went so badly wrong for these bikes, now we are at SJ and counting. The old "CC" spec was one of the first for diesels, also used for turbo engines.
