Author Topic: What's the best way to prevent flash rusting?  (Read 5341 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: June 03, 2013, 07:58:36 AM »
I cleaned out a tank yesterday with The Works toilet bowl cleaner.. actually 2 of them + filled to the top with water.. 2 hour soak. It did an awesome job - totally clean on the inside UNTIL I drained it out. Flash rust. Any suggestions for keeping that from happening again?
Offline lucky
Re: What's the best way to prevent flash rusting?
« Reply #1 on: June 03, 2013, 08:10:45 AM »
Steel starts to rust within 4 hours of cleaning.
It must be coated as soon as possible to keep oxygen away from it.
Some tank liners actually adhere to that flash rust very well.
Caswell's for instance.
I have applied Caswell's liner to a slightly rust interior with good results.
I add white colorant to the epoxy so I can see the inside condition of the liner.
I buy the white colorant from TAP plastics. It is a small  jar premixed and Caswell approved it.
« Reply #2 on: June 03, 2013, 08:34:48 AM »
Kleen Strip Prep-n-Etch.  works fine with flash rust.
pour a bottle in, top off with water.  leave it for an hour or so.
leaves a nice gray phosphoric acid coating.  no rust.
be sure to rinse it REALLY well with water after, then acetone to dry out the water, and then a little 2-stroke or ATF, if you will not be filling it with gas right away.
Offline 2wheels
« Reply #3 on: June 03, 2013, 09:15:41 AM »
After you drain the cleaner out,  rinse with water, blow with compressed air if you can to get as much water out as you can.  Then put a quart of alcohol (Methyl Hydrate is alcohol) rinse it around good.  That will absorb all the water. Dump it out and blow with air again.  Then  put 2 stoke oil in the tank and swish it around good.
All the above needs to be completed in about 10 minutes.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline Vinhead1957
« Reply #4 on: June 03, 2013, 09:28:35 AM »
Rinse it drain it use a hair dryer to get the rest of the water out and fill it with gas, mount it and run it
Offline davis96
« Reply #5 on: June 03, 2013, 09:30:18 AM »
+1 It won't rust if its got gas in it. This is what I did after using the works on my tank
'74 CB350F - sold
'71 CB500K
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: June 03, 2013, 10:07:12 AM »
You can also pour in some Marvel Mystery Oil (half a bottle or so) and swirl it around to coat the inside of the tank. That's what i did with mine and I only had a small amount of flash in a couple places where the oil didn't cover.
When you add gas later it will rinse off and it won't harm your engine to cycle it through.
Offline dusterdude
« Reply #7 on: June 03, 2013, 02:46:56 PM »
What danny said
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline chewbacca5000
  • I polish covers!
« Reply #8 on: June 03, 2013, 07:58:40 PM »
+1  faster the better.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #9 on: June 04, 2013, 09:01:59 AM »
I used fogging oil in mine worked pretty good for a few weeks while I was painting my tank. But yes dry it out as much as possible right after derusting it.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Scott S
« Reply #10 on: June 04, 2013, 05:30:38 PM »
 The Works and water and a heavy chain.
 Drain.
 Rinse with water.
 Water and baking soda to neutralize the acid.
 Drain.
 Rinse with water.
 Drain.
 Denatured alcohol to help evaporate water.
 Blow dry or set in the sun for a few minutes.
 Marvel Mystery Oil...about an ounce or two. Swish, spin, twirl, etc., to coat the entire inside.
 I had a tank sit at the bodyshop for a YEAR like this and it was still spotless.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
