Author Topic: CB550 Clutch pull  (Read 2280 times)
Offline Ian_Butler
  • Proud to be a
CB550 Clutch pull
« on: June 04, 2013, 11:18:23 AM »
Does anyone else have a 30lb clutch pull on their 550? I pulled the lever on my friend's 400 and his dad's sohc 650 and it was much lighter. I threw some WD-40 on the connecting rod outside the case and it made it slightly better. It's still very stiff. Anyone know how I might go about fixing this issue or is this standard? I cannot move the connecting rod by hand.
~ Ian
1974 CB550K
“In a car you're always in a compartment, and because you're used to it you don't realize that through that car window everything you see is just more TV. You're a passive observer and it is all moving by you boringly in a frame. On a cycle the frame is gone. You're completely in contact with it all. You're in the scene, not just watching it anymore, and the sense of presence is overwhelming.” ― Robert M. Pirsig
Re: CB550 Clutch pull
« Reply #1 on: June 04, 2013, 11:42:11 AM »
heavy duty clutch springs?
it might just need a clean and re-lube
Offline Lostboy Steve
« Reply #2 on: June 04, 2013, 12:01:22 PM »
After doing my clutch with the ebc hd springs and all, it is painful after a good ride because of the pull. Also has to do with my hard grips. I get a lot of discomfort in the thumb pocket area.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline totty
« Reply #3 on: June 05, 2013, 04:29:49 AM »
Disconnect the cable at one end and check it's running freely and smoothly. I'm about to try the same on my 550 as I'm finding it's clutch heavy.
Offline Ian_Butler
  • Proud to be a
« Reply #4 on: June 18, 2013, 08:12:03 PM »
Cable replaced. Operation is smoother but still very heavy. I don't think that the PO ever changed the springs. The lifter is impossible to move by hand. Could this be an adjustment issue?
~ Ian
1974 CB550K
Offline Dave Voss
« Reply #5 on: June 18, 2013, 10:05:06 PM »
Did you also lube the clutch cable?  Many new clutch cables are not adequately lubed when new, and require a good amount of lube to operate without undue friction along their length.
Also, check the routing of the clutch cable/sheath, there shouldn't be any sharp routing, especially up near the handlebar.  When I acquired my latest CB550, the clutch cable was routed under the left side of the bracket that supports the speedometer, instead of through the hole near it's base as it should be, and this caused the clutch pull at the lever to require a lot more hand strength.  Once properly routed, the clutch felt normal, rather than too stiff as before.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
« Reply #6 on: June 19, 2013, 05:47:24 AM »
I myself have checked this and honestly the cable has a pretty straight path. I think its just those hd springs. (On my bike at least.)
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Ian_Butler
  • Proud to be a
« Reply #7 on: June 19, 2013, 06:47:57 AM »
Routing is same as stock. I left the lifter arm end unattached, and the cable moved freely. No noticeable resistance. I read somewhere that the lifters get worn into grooves. Could this cause a hard pull?
~ Ian
1974 CB550K
