Author Topic: oil pressure light comes on after 20 minutes or so  (Read 5697 times)
Offline setdog
« on: June 05, 2013, 10:45:06 AM »
1976 cb750 k5
My oil light comes on after approx 20 minutes of rridingg.
Upon start the light goes out, stays out, but then pops on after nicely
Warm.
What might cause this aside from a bad sensor?
And how can I reassure myself that oil is flowing?
Can I just open the valve tappets and look?
I don't have an exterior gauge for this, and while I could purchase a new sensor
I want to know if there is way to make sure lubric action is okay.
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: oil pressure light comes on after 20 minutes or so
« Reply #1 on: June 05, 2013, 10:54:43 AM »
Start with the obvious, Check your oil level. Check for bad wiring under the chain cover. Pull the pan and make sure your oil intake screen isn't clogged. Do a fresh oil change and see if that changes anything.
Do you have any leakage on the ground under the chain cover? Could be worn out o-rings on your oil pump start sucking air and leaking oil when hot. Until you can sort out whether its a bad sensor or actual oil pressure loss I wouldn't run it!
« Last Edit: June 05, 2013, 11:08:12 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline setdog
« Reply #2 on: June 05, 2013, 11:36:28 AM »
Oil level looks good. Using 10/40.
Pulled the pump last week, screen is mint.
Changed oil then too.
No oil leakage on the ground, some common seepage around a Couple tappets
Or head gasket, not enough to set any alarms bells IMO.
Now the pump gaskets...I did not change but I think I'll go ahead and re gasket the pump,
There seems to be plenty of oil flowing, oil tank gets plenty warm so any blockage in that area
Is probably minimal but inclined to think its okay.
76 CB 200T. (sold)
Offline iron_worker
« Reply #3 on: June 05, 2013, 11:47:54 AM »
Your pump is likely worn and not producing pressure like it once did.
You should verify what your actual oil pressure is with a mechanical gauge set up at one of the oil gallery ports. If your oil pressure really is low then definitely don't run it like that.
IW
« Reply #4 on: June 05, 2013, 12:55:17 PM »
try another pressure sender unit,they are cheap.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: June 05, 2013, 02:05:14 PM »
Cheaper than a pump if it is the problem.
Offline 74750k4
« Reply #6 on: June 05, 2013, 02:31:11 PM »
Easy to install a pressure gauge at the end of the oil galley in the plug cap. Nice addition to your idiot light as well.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: June 05, 2013, 03:11:46 PM »
+1 on the gauge. An added benefit is you get to see how low the oil pressure can go when you are idling at a light in 90+ degree temps.  ;)
Offline Prospect
« Reply #8 on: June 05, 2013, 04:27:49 PM »
Do you notice any changes in shifting or clutch. I had the same problem and it turned out to be a worn pump. The clutch basket wasn't getting enough oil and shifting was difficult. If your shifting is ok then possibly the oil sensor needs replacing.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #9 on: June 06, 2013, 10:17:39 PM »
Try 20w50
« Reply #10 on: June 07, 2013, 04:15:34 AM »
How high is the idle?  With Mobil Delvac on a warm day, the oil light would come on around 900rpms, yes it was bit low for an idle.
Offline lucky
« Reply #11 on: June 07, 2013, 06:12:10 AM »
How many miles on it?
IF it is over 30 years old little bits of rubber can come off of the cam chain guide rollers and get clogged up inside the oil passages of the crankshaft.
If you found noting in the oil pump screen you are probably ok.
If it was me I would buy a new oil pressure sending unit and see what results you get if any.
If the bike has more than say 70,000 miles, the oil pump gears could be worn and you can measure those.
bollingball
« Reply #12 on: June 07, 2013, 02:02:51 PM »
Have you changed those three o-rings by the metal collars 15x2.5mm There is also one o-ring under the shifter cover. It has been said that these four o-rings will help maintain constant pressure. part 14
http://www.cmsnl.com/honda-cb750k6-four-usa_model14380/partslist/E13.html#results
Ken
bollingball
« Reply #13 on: June 07, 2013, 02:24:56 PM »
Here is the walk through on these o-rings.
http://forums.sohc4.net/index.php?topic=78643.0
Ken
