So I reinstalled the carbs with the new bowl that I got (thanks a million harisuluv). They are definitely clean (jets are clear, in fact I don't even think they needed clearing, but cleared them I did), no leaks, great vacuum. However I still can't get the bike to start. Really I'm still experiencing the same symptoms
1. When I try to start the bike, with the choke fully out, I'm definitely getting something, but it sputters out after a couple of seconds. If I try to give it any throttle it immediately dies (it doesn't even sputter for a bit).
(It's worth noting that with the choke in I get nada)
If anything it seems worse, the sputtering is weaker, and it's dead with any throttle. These symptoms might be distracting, my question is this: What next?
I think the spark plugs are sparking properly (looks good when I ground them on the bike), I haven't really looked at the points. Does anybody have any really obvious notion of what this is? Otherwise I'm going to be banging around in the dark, maybe go get a salvaged ignition coil and see if the spark increases in strength (I can't tell if the spark I'm getting is strong or not).
Any thoughts will be greatly appreciated.
