Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Be ready to get charged one hour labor regardless if it takes them to burn it in 5 minutes.
Quote from: jpfrk2001 on September 07, 2013, 05:17:17 PMBe ready to get charged one hour labor regardless if it takes them to burn it in 5 minutes.This is true... But Competition Cycle doesn't do this. I had them do a simple weld on a license plate bracket I fabed up for my 550 and they charged me $10. Another time I had them weld a 3/8 drive articulating knuckle on a thin wall spark plug socket for $5.I have always wanted to do my own welding for this type of simple stuff. I might need to take another look at a welder.
Quote from: Tews19 on September 06, 2013, 01:52:46 PM18x2.15 40 spoke aluminum rim..... look up rustyolive on here... he did a larger wheel on his 550 build. He had to fab up a swing arm....Oh... hello! hahahaI laced up a 18x 5.50 (drilled and punched from Buchanans) to stock cb550 hub with over sized stainless spokes/nips.
Quote from: RustyOlive on September 07, 2013, 06:41:18 AMQuote from: Tews19 on September 06, 2013, 01:52:46 PM18x2.15 40 spoke aluminum rim..... look up rustyolive on here... he did a larger wheel on his 550 build. He had to fab up a swing arm....Oh... hello! hahahaI laced up a 18x 5.50 (drilled and punched from Buchanans) to stock cb550 hub with over sized stainless spokes/nips.How much did this run you if you dont mind me asking
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either. Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
Once I get the frame modded I should really pick it up..
So, I must have missed it. What is prompting the rear frame reconstruction? Changing build plans?
