Author Topic: Tews' 605 build, On the road! 5/4!  (Read 89659 times)
Offline ISLAND CAFERACERS
Re: Tews' build GSXR front end, 11/11 engine disassemble
« Reply #250 on: November 14, 2013, 10:17:14 AM »
Tews its looking good an inspiration
cheers Andy in the UK
Offline edhaeuser
« Reply #251 on: November 14, 2013, 11:56:44 AM »
I had a really hard time getting my base gasket off also.  Hours of solvents and scraping.  My cases were split so I ended up finishing up with the soda blaster.  Good Luck.
« Reply #252 on: November 14, 2013, 06:01:09 PM »
Tews - a new, sharp chisel will remove that gasket.  But don't get crazy with it.
Offline Tews19
  • I am no
« Reply #253 on: November 16, 2013, 09:31:48 PM »
Decided to pull the oil pan. The front of the engine is full of gunk... A few bolts look as if oil is seeping... I pulled the oil strainer. No metal flakes which is good. Hopefully some can chime in. The inside looks really clean. All teeth look great. No rub marks anywhere in the cases.... Should I be looking for anything out of the ordinary? The chain does slide side to side.... Is that normal? The oil line is rock hard... Shall I replace?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1970 Honda CB750 survivor.
Offline Mcwilliams570
Re: Tews' build GSXR front end, 11/16 oil pan removed, Need insight
« Reply #254 on: November 17, 2013, 02:14:56 PM »
Tews it looks good I have never replaced the oil line should be good but I am a cheap bastard. No rub marks you should be fine.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline rb550four
« Reply #255 on: November 17, 2013, 06:06:57 PM »
I'm with Matt on that, the rubber tube is basically stationary , so as long as it isn't cracked or brittle....Why change it .
How slack is the primary chain and how slack was the camchain when you removed it? If you suspect you could use a new one of either, get both new. If you are adding more horse power to the engine and you already have a swinging primary or a slack cam chain now's the time to do it.
 Why do people turn engines over if they aren't going to split the cases? Because the pan is off only makes this a little better, below your clutch , on the flat spot under the kickstart shaft, the pockets that are just under the crank, the drain plugs that are still in..... all the wasted particles from your clutch and other engine wear lay in these areas , now by turning the case over all that stuff will be infecting the crank bearings,and primary bearings, now it's free to get into all the bearings, backfeed to the oil pump and get all over the gears ....  Well , anyways I hope that if your chains look slack that you would consider splitting the cases , clean it all out real good, spill some oil on everything and change out the chains.
 Dirt and other particles on the bottom of an engine should either be left at the bottom or cleaned out, never allowed to re infect the motor
« Last Edit: November 17, 2013, 06:16:04 PM by rb550four »
Offline Tews19
  • I am no
« Reply #256 on: November 17, 2013, 06:13:51 PM »
Primary isn't loose.. Only moves a little and that's if I put pressure on it. Cam chain is in really good shape and also very little play if any.
Thanks for the insight guys.
« Reply #257 on: November 18, 2013, 06:06:11 PM »
+1....I see no problem. You order gaskets yet?
Offline Tews19
  • I am no
« Reply #258 on: November 18, 2013, 09:08:49 PM »
No gaskets ordered yet. Any sets you would recommend? I gave up on the foam seat. It made a mess and looked like #$%*....I will modify the one I already have.
« Reply #259 on: November 18, 2013, 09:16:30 PM »
I like the Vesrah, good quality at a fair price.  There are others that are slightly cheaper though.
http://www.ebay.com/itm/Vesrah-Complete-Gasket-Kit-Honda-CB550K-74-78-CB550F-Super-Sport-75-77-/111075620814?pt=Motorcycles_Parts_Accessories&fits=Model%3ACB550&hash=item19dc9f77ce&vxp=mtr
BTW - I cannot see some of your pics above for some reason. The last pic in reply #255
Offline Tews19
  • I am no
« Reply #260 on: November 18, 2013, 09:18:14 PM »
Not sure why... My galaxy shattered and insurance sent me a replacement. I downloaded Tapatalk but the new version is funky.... It was another view of the internals of the engine from the oil pan area.....
Offline jojo
« Reply #261 on: December 03, 2013, 12:22:07 PM »
tews- any type of progress recently? I know its been hard for me due to the holidays and travel. Trying to finish my build before christmas which i know is pushing but one can only dream! ;D
Offline Tews19
  • I am no
« Reply #262 on: December 03, 2013, 12:28:56 PM »
No update. I sent off the head and cylinders to get bored. Waiting for the brackets to be made to have the rear shocks be mounted. I am debating if I want to buy a wheel stand to true the wheels myself.
Offline jojo
« Reply #263 on: December 03, 2013, 12:32:39 PM »
I bought one but ended up paying to get them trued. I laced them but didnt want to deal with the trueing part of it. ive seen people put the swing arm on a vice and use the axle as kind of a makeshift stand. I kind of regret buying it because i doubt i will have much use for it in the future.
Offline edwardmorris
  • Youngish
« Reply #264 on: December 03, 2013, 01:04:51 PM »
What did it cost you? I might take a crack at it when I get to my wheels and may need it. PM me if you want to get rid of it. I'm waiting to see Tews' engine work when it's back. That part I may get done professionally...
Offline cheftuskey121
  • Super Newbie
« Reply #265 on: December 03, 2013, 01:22:33 PM »
do it Nick, I got my truing stand for under $100 and it took me 4 hours to do both wheels the first time, and only 30 minutes to do the front wheel the second time. once you get the hand of tightening what to move sections you want, its easy. a shop was going to charge me $270 to do both wheels so it was a no brainer for me. I did not want to do it myself initially either but am very glad I went for it. very satisfying. its like a dying artform but you'll know that your wheels are true. remember no one loves your bike like you do. I try to farm out as little as possible. love the build man, can't wait to see more updates!
Offline Tews19
  • I am no
« Reply #266 on: December 03, 2013, 07:42:23 PM »
Hey chef where dis you get yours? I think I'm pulling the trigger and getting one. Do you have the torque wrench that Trusk sells?
  • Super Newbie
« Reply #267 on: December 03, 2013, 07:47:15 PM »
I got mine on ebay, brand is called "Tusk". it is similar to my last name so I bought it! haha. great stand. I also picked up a runout gauge and magnetic base on amazon. I think all in all it was close to $110 or so. not sure what torque wrench you are referring to
Offline Tews19
  • I am no
« Reply #268 on: December 03, 2013, 07:54:21 PM »
Yes, Tusk.. Not Trusk...
How To True A Motorcycle Wheel
  • Super Newbie
« Reply #269 on: December 03, 2013, 07:58:02 PM »
haha yep thats the stand! I liked the built in level so you can make sure you're starting out right. make sure you put the outside round clamps as far outward as you can so they rub up against the bearings otherwise the axle will shift one way or another as it spins. putting those clamps pressed up against the bearings prevents the axle from going anywhere (preventing your wheel from shifting left or right and ruining your reading.
once I figured that out it was a breeze to use.
Offline Tews19
  • I am no
« Reply #270 on: December 03, 2013, 08:00:22 PM »
I will give them tomorrow. Maybe get a cheaper price then on Amazon.
  • Super Newbie
« Reply #271 on: December 03, 2013, 08:02:30 PM »
and after watching the video I see the toque wrench, I used a standard spoke wrench, nothing fancy. I have a lot of experience tuning guitar strings so after I trued it vertically and laterally I checked the pitch (relative tension) of each spoke. I got them to be similar in ping, and checked for true again. had to make some adjustments and compromises. I cant remember the honda measurement for a trued wheel but I was WAYYY under the tolerance. easy to do if you have patience. that torque wrench seems cool though, but I think it isnt necessary
I never had any wheel wobbling or related issues after truing. I did have a shop mount my tires but I balanced them myself because I did not want sticky weights on my rim, I wanted the vintage weights on the spokes.
Offline Godffery
  • Godffery's Garage
« Reply #272 on: December 04, 2013, 01:11:12 AM »
cheftuskey,
If you want to go completely without wheel weights, use DynaBeads.
 DynaBeads demo video
  • Super Newbie
« Reply #273 on: December 04, 2013, 04:13:27 AM »
cheftuskey,
Thanks godffery. I looked into those but I like the look of the vintage style wheel weights and have had no issues with them as of yet.
Offline Godffery
  • Godffery's Garage
« Reply #274 on: December 04, 2013, 08:22:34 AM »
Well then...
You really want the vintage look, You could go with the old led solder trick:
