Author Topic: Tews' 605 build, On the road! 5/4!  (Read 83403 times)
Re: Tews' build, 605CC with 2 wheels! end is near!
« Reply #400 on: July 20, 2014, 11:46:50 AM »
The end is near?
Has anyone told Tews that the last 20% of a build takes 80% of the time?!
« Reply #401 on: July 20, 2014, 11:50:17 AM »
Well it's time again for a cough cough, cafe build. I really do not like using the word cafe as it has become cliche' but it's what I am going for with this build.
Me, too...I propose the "old days" moniker be resurrected? When it was impractical to replace all the parts during a resurrection of XYZ bike (for financial or availability reasons) we called them "Lightened Customs". :D
Offline ogsmakdade
  • bike newb
« Reply #402 on: July 25, 2014, 07:48:19 AM »
bike looking good man.
thanks for the info on the craftsman lift, I'm going to pick one up so I can change my tires and brakes.
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
« Reply #403 on: July 25, 2014, 08:28:35 AM »
The prob with those lifts on our CBs is that they push up on the exhaust system, not the best, and removal of the exhaust is not always convenient, often. Of course if the project is at the sans exhaust stage, then alls well.
Harleys work well on them as the pipes are above the frame rails.
Offline Tews19
  • I am no
« Reply #404 on: July 25, 2014, 08:33:42 AM »
Mc is spot on. They work great but with no exhaust!
1970 Honda CB750 survivor.
Offline edwardmorris
  • Youngish
« Reply #405 on: July 25, 2014, 08:39:27 AM »
Thanks Ron, I hadn't even thought of that. I'll put it off for now, might not be worth having it just for assembly. I'll have to rig something up interim.
Offline Tews19
  • I am no
« Reply #406 on: July 25, 2014, 11:00:41 AM »
I will have to look into a paddock stand.
Offline Trad
« Reply #407 on: July 25, 2014, 03:54:53 PM »
Coming together nicely. Looks super good Tews!
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #408 on: July 25, 2014, 04:50:24 PM »
I used lag screws to mount a piece of angle metal to my garage rafters. Now I can hoist the bike into the air with a cable strap. Handy.
Offline Tews19
  • I am no
« Reply #409 on: July 25, 2014, 06:29:55 PM »
Well if I need to lift the front end I usually use my trusty 2x4 I cut to length to lift the front end up from under the neck.
Offline Tews19
  • I am no
« Reply #410 on: July 28, 2014, 07:25:08 PM »
I really thought I would have this finished by this weekend but I messed up. While installing my bronze bushings I made one crumble. Not a big deal as I ordered another set.
I want to install the exhaust and curious what you all do when installing on a fresh head?  I have the new copper washers. Do I use some type of sealant as well?
Those who have the motogp exhaust,  did it come with nuts to mount the flanges? I looked in my bag with springs and nothing.
« Last Edit: July 28, 2014, 07:37:23 PM by Tews19 »
Offline Trad
« Reply #411 on: July 28, 2014, 07:36:21 PM »
The Motogpwerks pipes don't come with flange nuts. Just reuse the ones you had. No sealant on the copper crush washers or exhaust ports either. No need IMO. Just tighten the nuts evenly and to the correct torque spec. I can't remember what that value is off the top of my head. Others may be able to chime in. Excited to see it finished Tews!
« Reply #412 on: July 28, 2014, 07:52:00 PM »
+1 no sealant on the header.  I use a couple dabs of grease to hold the gaskets to the head, if necessary.
Offline goldarrow
  • one day, i'll be an
« Reply #413 on: July 28, 2014, 11:33:29 PM »
You might want to treat the pipes collars before you run them.  Heat makes them look very ugly on a nice looking bike
CB550 K0
Offline goldarrow
« Reply #414 on: July 29, 2014, 09:11:34 AM »
CB550 K0
Offline Toustic
  • I can levitate birds... But nobody cares
« Reply #415 on: July 29, 2014, 12:19:22 PM »
I really like that seat you got yourself there  ;)
Looking forward to see how you're going to pad it up
"I totally take back all those times I didn’t want to nap when I was a kid."
Offline Tews19
  • I am no
« Reply #416 on: July 30, 2014, 10:04:33 AM »
Tews - I install only the flanges without the pipe connected: it makes it much easier. I always buy new SS 6 mm nuts when I install an exhaust and put a tiny dab of anti-sieze on the stud threads.
By separating the flange from the pipe, you can easily install the copper gasket too. When all is in place, I attach the pipe by the springs, hooking the flange first, then pulling away from the motor. Wicked simple this way.
Thanks Cal! I will follow your advice!
Gold dude- a member has really helped me out with the exhaust to help preserve most of it's originality.
Bad part is this build will most likely be ridin' next season. Nights are down to 50 already.  My K1 has just over 1k for this season and August is always a hectic month on weekends with weddings and end of summer BBQs
Offline goldarrow
« Reply #417 on: July 30, 2014, 10:21:43 AM »
Wow nice low mileage K1!
I put 100 miles a day, 5 days a week, 4 weeks a month, and 10 months a year,  on my bikes :(
CB550 K0
Offline goldarrow
« Reply #418 on: July 30, 2014, 10:26:45 AM »
Please get a JOB!
Lol.  I commute, ride bike to work. :)
CB550 K0
Offline Tews19
  • I am no
« Reply #419 on: July 30, 2014, 10:31:20 AM »
If I was single I would easily put 10k on a season but I try to be as involved with the family as I can. So anytime on the bike is really enjoyed.
  • Youngish
« Reply #420 on: July 30, 2014, 11:33:18 AM »
Its only July dude, you never know when the gates of hell will reopen and we go back to the dreadful 90s. I'm hoping to get mine riding this season, lots of little things left to do and never enough time. When should I give up on this season? Mid Sept?
Offline cb550inct
  • I am really good at buying parts
« Reply #421 on: July 31, 2014, 08:13:13 AM »
Tewes i got brand new flange bolts from Honda for like $15 when i put on the Lossa Exhaust. And Just before the i sold the bike i had the exhaust coated with a high temp satin finish.( i swear it made the bike run smoother.)
And you need to ride more!
1978 cb550k
1998 Harley Springer Softail
2004 Harley Heritage Softtail (sold)
2001 Vespa 150 (sold)
1980 Kawasaki Kx 80  (first Bike)
Offline Tews19
  • I am no
« Reply #422 on: July 31, 2014, 01:03:07 PM »
Cal do you happen to know the pitch for the 6 mm nuts? I want to pick up some soon.
Offline Tews19
  • I am no
« Reply #423 on: August 04, 2014, 09:33:10 AM »
I'm finishing up the rear hub and have hit a snag. I bought the hub plate from a member last year thinking it was for a 550. I removed the brake spindle from on hub plate to the nice chromed one but it doesn't fit. I tried 2 other face plates and same issue with the chrome plate. None will work for it. I may have to use an old one and not this nice shiny one.
Offline goldarrow
« Reply #424 on: August 04, 2014, 09:35:51 AM »
in the second picture, one plate is a 750, the other is 550
CB550 K0
