Author Topic: Dent on frame rail  (Read 4590 times)
Offline bultaco59
Dent on frame rail
« on: June 15, 2013, 05:16:30 PM »
Hello people, does anybody out there have any ideas how pull a dent out of the frame, its right in the front, and it really pisses me off because know matter how much work goes into the build that's the first thing there gonna see, if anyone has a trick up there sleeve please let me know. I'll post a pic.
Thanks
Bob in burbank
Offline Vinhead1957
Re: Dent on frame rail
« Reply #1 on: June 15, 2013, 05:26:21 PM »
Drill a  hole, use a dent puller and weld the hole
« Reply #2 on: June 15, 2013, 07:09:31 PM »
And have the frame checked for straightness.... ;)  I have a K2 frame with a dent in the same spot and after having it fixed I'm having it put on a frame jig and checked...
« Reply #3 on: June 15, 2013, 07:22:22 PM »
That is from the 20$ hiway bars it  used to have.. Some bondo them, pita to fix.
Offline Icarus
    • Icarus Frames, my bicycle frame building company
« Reply #4 on: June 15, 2013, 08:17:12 PM »
I'm a brazing guy so I just say lay some brass in there to fill it up an then a quick sanding.  Classier than bondo and powder will stick to it.
1975 CB400F
1977 CB550K
avatar is a previous moto project
Offline lucky
« Reply #5 on: June 15, 2013, 08:54:07 PM »
If you heat the center of the depression with a torch to dull red it initially expands. May pop out wards.
After it cools it will shrink just slightly. It should look slightly better.
Do not put water on it. Just let it cool at room temp.
If you drill a hole in it and use a dent puller it could look worse because the tent puller will make a protruding volcano shape. I would not do that.
If you weld the hole that the dent puller requires that will cause shrinkage as it cools. It will just look worse.
I think I would go with the Bondo myself. It will look perfect.
Offline kghost
« Reply #6 on: June 15, 2013, 09:15:05 PM »
I would TIG weld it then grind to match........but I have a welder
Stranger in a strange land
Offline bultaco59
« Reply #7 on: June 15, 2013, 09:40:57 PM »
Hey guys thanks for the response, I guess the best way for me is to lay some brass in the dent.
one question, does map gas get hot enough to melt brazing rod ? since I don't have a turbo torch.
If not I'll have to bring are tig welder from work home and try that. I now have options, thanks again.
Bob in burbank
Offline Vinhead1957
« Reply #8 on: June 16, 2013, 04:49:15 AM »
You have never pulled a dent I see.  Yes the hole will pull high like a volcano but you hammer and grind it back down and then fill the hole.  You can fill with lead (old school) fill with brass(braze) or weld with steel.   Bondo on a frame for only cosmetic dings only.  Frames flex and the inconstant densities. Bondo (soft) steel (hard) will crack at edges.
Offline Powderman
« Reply #9 on: June 16, 2013, 08:28:46 AM »
JB Weld, sand and paint. JB Weld can be powder coated, Bondo can not. Is there another reason for fixing the dent other than cosmetic?
« Last Edit: June 16, 2013, 08:54:03 AM by Powderman »
« Reply #10 on: June 16, 2013, 08:38:35 AM »
A split die for 1 inch tube, may reround it, but its tricky..and involves heat..
What I mean is 2 square blocks bored to one inch id.. Like we use on fork straightening.
« Last Edit: June 16, 2013, 08:40:39 AM by 754 »
« Reply #11 on: June 16, 2013, 09:58:49 AM »
Offline lucky
« Reply #12 on: June 16, 2013, 12:58:49 PM »
The TIG weld would make the least heat input with the most penetration but
there would still be shrinkage and you would still have to bondo it after sanding.
Never use a grinding wheel on a 1/16-.060 thousandths thick frame tube.
One touch of the grinding wheel and 1/3 of the material could be gone.
Offline mec
« Reply #13 on: June 16, 2013, 01:17:45 PM »
my way: drill a hole opposite side of the tube, hammer the dent, weld the hole.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline cosmicvision
« Reply #14 on: June 16, 2013, 02:33:11 PM »
I read a topic on here once about the guy that had a weird fork angle & couldn't figure out why, and ruled it to be the frame being slightly skewed. It was intense, replete with the horror stories of off-kilter frame geometry sending you into a tank-slapping fiery blaze. Not sure how much effect a dent of that size would have...thought it was worth mentioning though.
-Joshua
1974 cb550 - back of the garage for now
1979 cb650 - daily rider, mac 4-2, clubman, murray's carbs, guiliari type seat
« Reply #15 on: June 16, 2013, 03:03:55 PM »
mec
Good thinking Mec.... ;)
Offline lucky
« Reply #16 on: June 16, 2013, 03:52:55 PM »
mec
  That sounds very interesting. I like it.
Offline Vinhead1957
« Reply #17 on: June 16, 2013, 05:14:31 PM »
Mec that is not a bad idea!
Offline kghost
« Reply #18 on: June 16, 2013, 05:46:51 PM »
I would build it up with the TIG.
I agree don't use a huge electric grinder.
After build up.......sand it back with a rol-lock disc on a 1/4 air grinder aka the wheeng wheeng tool lol
« Reply #19 on: June 16, 2013, 06:40:16 PM »
If you tig, it use phosphor (EDIT) SILICON bronze rod. It's easier to sand down and requires less heat causing less shrinkage. It worked fine on mine. Most of the above ideas work too.
« Last Edit: October 26, 2013, 06:46:43 PM by Don R »
Offline Dave Voss
« Reply #20 on: June 16, 2013, 08:19:12 PM »
If the frame is not bent or distorted in any way, then that dent is not enough to warrant any repairs.  Although it could be straightened out, the drilling of holes, pulling/pushing action on the metal tube, etc. will weaken the frame, which then is dependent on the quality of the repair to restore the original strength.  Even then, it will be very difficult to remove the dent such that it won't still be obvious where it was, in which case some filler will be required to hide it.  So if this is being considered for cosmetics, then I would recommend just filling the dent as-is, instead of trying to remove it first.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline lucky
« Reply #21 on: June 18, 2013, 10:50:08 AM »
If you tig, it use phosphor bronze rod. It's easier to sand down and requires less heat causing less shrinkage. It worked fine on mine. Most of the above ideas work too.
Most welding suppliers only sell silicon bronze filler wire.
Offline CapeCafe
« Reply #22 on: June 18, 2013, 01:39:40 PM »
Dent the other side to match :)
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
« Reply #23 on: June 18, 2013, 04:13:13 PM »
I stand corrected,  thanks.
Offline bultaco59
« Reply #24 on: June 18, 2013, 06:18:17 PM »
If none of the other options work, that to is an option. granted not the best option,but an option none the less.
