Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
I like that 450 of Larry's because it looks a bit like a CB750. If you could just pull that rattly boat anchor of an engine out and install an SOHC4 in there, it'd be a truly impressive bike!
Very impressive, Larry! I've always liked the 450 side cover badge for some reason.
Quote from: Terry in Australia on July 05, 2013, 05:15:23 PMI like that 450 of Larry's because it looks a bit like a CB750. If you could just pull that rattly boat anchor of an engine out and install an SOHC4 in there, it'd be a truly impressive bike! You do it to yourself. The 450 is more efficient than the 750 SOHC. Fact.
Quote from: fendersrule on July 05, 2013, 06:30:00 PMQuote from: Terry in Australia on July 05, 2013, 05:15:23 PMI like that 450 of Larry's because it looks a bit like a CB750. If you could just pull that rattly boat anchor of an engine out and install an SOHC4 in there, it'd be a truly impressive bike! You do it to yourself. The 450 is more efficient than the 750 SOHC. Fact. So's the C50. Fukt.
I better add you down under guys to my buddy list. Keep an eye on this bunch. tt
Morning tt, only 81 here at 10:30am......done sipping coffee, plan to be sipping some cervesas on the boat shortly.Night night Aussies
