The SOHC/4 World Tour is in under way.
Trying to start my bike after a complete rebuild, it has spark but only carb #1 is filling up with fuel, the #2 is okay, #3 and #4 are completely dry after kicking it at least a thousand timesAny ideas?
Kicking the engine will not make fuel flow into the float bowl.If you kicked it a thousand times you could have damages something in your leg or bike.
Ok the drawing is good and all but how bout some pictures of your carbs..
Before you remove the carbs from bike try just removing the bowls..Turn on your gas and see if you get FREE flow out ALL carbs!! Look to see if the needles drop with the floats if you don't get gas flow. SOMETIMES you can remove the float pins and floats and look at the needles.Xnavylfr(CHUCK)
OK, so you're getting fuel into carb 1 & (maybe) 2? Why not disconnect the fuel tube from the inlet to carbs 3 & 4 and confirm that fuel is making it to that point? If fuel is flowing from the tube there then that kind of narrows it down to the needle & seat of 3 & 4.
You mentioned vacuum so I have to ask where is the fuel line coming out of your temporary fuel supply?
