Author Topic: install CB750 speedo and Tach on a CB500  (Read 1000 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: June 16, 2013, 11:40:28 AM »
Hello,
This is my first post so bare with me, I'm restoring a 1973 CB500 which was a 60th bday present (bought from the original owner with 1243mi),
 My question is can you install a CB750 tach and speedo on a CB500.
The size is not a problem and redline is different on tach and top speed is higher. Are the drive ratios the same. Im having trouble finding a new or almost new CB500 speedo and tach.
thanks,
Mark
Roseville, Ca
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline LesterPiglet
  • 1977 CB550F2
Re: install CB750 speedo and Tach on a CB500
« Reply #1 on: June 16, 2013, 11:43:27 AM »
750 tach has a different ratio. Look for 550 as well as 500.
Offline rtbmrgl
« Reply #2 on: June 16, 2013, 12:33:17 PM »
Ok thanks
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #3 on: June 16, 2013, 04:53:47 PM »
another question,
the odo reset button is missing, I'll be looking one ebay for another speedo unless I can find pieces,
Do the reset buttons screw in.
I think I will get new faceplates and rebuild these
thanks, Mark
Roseville, Ca
Got Points!
« Reply #4 on: June 16, 2013, 05:00:48 PM »
Some have a set screw in the knob, whereas some are threaded on opposite thread of normal reset direction...
FWIW,
If you put a CB650 cam & tach drive gear in your CB500/CB550 then you can use the CB650 or CB750 tach.
