Author Topic: 1977 CB550F  (Read 610 times)
Offline MARS9735
1977 CB550F
« on: December 07, 2021, 02:25:46 PM »
Looking for some input. I have a 77 550F that I will be installing a carb set from a 78 550K. Other than the choke location, what other issues could I anticipate?
Any input would be much appreciated.
Thanks
Re: 1977 CB550F
« Reply #1 on: December 07, 2021, 03:13:02 PM »
Sketchy information given, imo.
Some differences:
Intake runners
Intake runner rubber couplers
Intake carb rubber couplers to air box.
Throttle cables (both)
The jetting is way different; Mains, slide needles, pilot jets
What exhaust is being used?  (It matters.)
What air filter assembly are you using?  (It matters.)
Re: 1977 CB550F
« Reply #2 on: December 07, 2021, 03:15:58 PM »
Airbox and rubbers different, very lean burn but my question is WHY?
You are removing easy to work on carbs that are relatively unfinicky and easy to get parts for and fitting the most awfull carbs that are a swine to clean and get parts for plus a real #$%* to set up
Re: 1977 CB550F
« Reply #3 on: December 07, 2021, 04:20:57 PM »
... but my question is WHY?
+1.  I have a '76 550F and it runs great with the 069 carbs.
