Author Topic: side mount for a license plate  (Read 1963 times)
comcrx
« on: August 03, 2006, 01:08:13 PM »
has anyone made/fabbed their own? if so, what did you make it out of and where did you mount it?
Offline StevieMac
Re: side mount for a license plate
« Reply #1 on: August 03, 2006, 01:16:45 PM »
I haven't made one but it would be very easy to do.   I would use 1/8" aluminum plate (since I have lots on hand & you can polish it if you are so inclined).
Trace the shape of the license plate on the aluminum and then draw on an extra section for a mounting tab to the bike.  Cut out shape, drill mounting hole in tab, drill holes to mount license plate, bend tab at a 90 degree angle to the plate.  You can mount it to the top or bottom shock mount.
I like my plate mounts to make a full back plate for the license plate as I think it looks a little nicer so that's why I use aluminum plate.  If you don't care about that you could just use a strip of band iron bent & drilled to mount on the shock mount.
You may want another tab above the plate to mount a plate light.
Make sense?
72 CB500 Cafe
78 CB750 Chopper
Gallery: http://www.sohc4.us/gallery/v/members/personal/StevieMac/
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: August 03, 2006, 01:43:50 PM »
Do a search for "Side mount license plate".
Offline StevieMac
« Reply #3 on: August 03, 2006, 01:49:04 PM »
Now that I think about it my chopper actually had a side mounted plate when I bought it.   It was just made out of a piece of band iron that was welded to the frame down by the rear axle.  The first week I had the bike I probably tripped over that stupid thing 1/2 a dozen times  >:( (The plate was mounted horizontally and we have fairly large plates here).
The hacksaw came out after +/- time #6 (slow learner.....)
« Last Edit: August 03, 2006, 01:50:37 PM by StevieMac »
72 CB500 Cafe
78 CB750 Chopper
comcrx
« Reply #4 on: August 04, 2006, 06:43:57 AM »
yep, I get what you're describing. I think I'll wait til the fall when I have access to a metal shop and get er done
thanks
Offline dusterdude
« Reply #5 on: August 04, 2006, 07:43:28 AM »
yea,they look good,but you`ll trip over that thing all the time.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Lumbee
    • My pics...
« Reply #6 on: August 04, 2006, 07:48:28 AM »
...this is what I got on my chop...
http://www.jpcycles.com/ProductDetail.aspx?PID=9700115&cs=All
...pretty cheap, and easy to mount...duster is right, I crack my shiin on mine at least once a week...
...hey Mark, how do you like my avitar!!!   ;D
"I'm not a welder, but I play one on HondaChopper.com"
Offline dusterdude
« Reply #7 on: August 04, 2006, 07:55:45 AM »
been trying not to comment on that,but since you asked.you should clean your yard more often. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Lumbee
    • My pics...
« Reply #8 on: August 04, 2006, 07:58:03 AM »
 :D  I figured you had to have seen it by now...just wanted to make sure you didn't hold it against me...   ;)
Offline STLrocker
  • whiskey bent and hell bound
« Reply #9 on: August 04, 2006, 09:09:34 AM »
i've made a few. one i made from stainless sheet. it was like stevie described. just cut the shape and bent. then i made two from some stainless rod. i used a nut to go over teh shock mount and bent teh rod to the shape i wanted then welded it together and welded a piece of sheet metal on for the plate to atatch to. poor description. look at the pic
Offline StevieMac
« Reply #10 on: August 04, 2006, 09:12:44 AM »
STLrocker,
I dig that dude!  Nice idea with the rod.  Looks cool and very original.  Well done.
72 CB500 Cafe
78 CB750 Chopper
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #11 on: August 04, 2006, 09:38:47 AM »
I just took a old stopsign (I have lots of signs on my garage that I have "accquired" over the years) and cut out a simple plate mount, and curved the top for the LED strip. Made a "L" Bracket and mounted it off the bottom shock mount bolt. Nice and simple..
I had a cateye on their before, but I got sick of it.
Gonna revise it once again over the winter, with some lights I picked up here at work that are sick ass bright.
« Last Edit: August 04, 2006, 09:42:55 AM by ProTeal55 »
Offline dusterdude
« Reply #12 on: August 04, 2006, 10:07:37 AM »
shoot mark,if i let stuff like that bother me,i would of shot my man elcheapo long ago for his anti harley stuff. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
