Author Topic: Anyone Have a Water Jet Table?  (Read 1712 times)
Offline Powderman
« on: June 17, 2013, 02:12:01 PM »
I need to have a couple of H-D cylinder base gaskets made from .070-.080 aluminum for the race bike to gain some valve clearance. Are any of you in a position to help? It is the last thing needed to get my motor back together after being in the shop close to a year.
Thanks,
Marc
Re: Anyone Have a Water Jet Table?
« Reply #1 on: June 17, 2013, 02:14:31 PM »
I thinkmaybe Elan.. Had access to one.., not surehe canhelp..
Offline gschuld
« Reply #2 on: June 17, 2013, 02:26:47 PM »
Give me a call.  I may be able to help you.
George
732-966-seven nine eight one
« Reply #3 on: June 17, 2013, 02:38:55 PM »
Hey cant find your sprocket shaft thread george..bring it back up, will add a bunch of info..
« Reply #4 on: June 17, 2013, 03:01:19 PM »
Crush has access to a laser, don't know if it would have the power to cut thin aluminum...just a thought.
Offline Tintop
« Reply #5 on: June 17, 2013, 07:03:24 PM »
I've had a bunch of things cut by these guys for my 550, there the ones I sent syscrush too, and Denis @ CMR Racing uses.  http://www.haiwaterjets.com/  However they are in Canada.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline cabrala
  • Super Duper
« Reply #6 on: June 17, 2013, 07:25:17 PM »
Unfortunately neither of my lasers are powerful enough to get the cut through aluminum. I'd think a water jet or high-powered laser would make very quick work of it. Best of luck. I'd like to hear where you end up.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline gschuld
« Reply #7 on: June 17, 2013, 07:31:39 PM »
Frank,
http://forums.sohc4.net/index.php?topic=122301.0
Just bumped the thread to the top.  It is in the sohc/bikes section rather than the High performance section.  I'm regretting that one... thanks.
Powderman,
      What bore do you need these cut to?  I'd be happy to help if I can.  I'm in NJ.  The guy I use just recently made me very accurate custom pieces out of 3/4" solid silicon bronze plate.  I doubt .070" aluminum would present a problem. 8)
George
Offline Stilltime
  • Building my Dream
« Reply #8 on: June 17, 2013, 08:28:29 PM »
I have access to a waterjet at work if you have a DXF of the gasket.
Just had these cut from 3/8" aluminum for my 550.
Let me know if I can help out!
Chris C.
'78 CB550 - Orange Crush
Offline Big Jay
    • CBRzone
« Reply #9 on: June 17, 2013, 09:52:35 PM »
We could supply .080"  What size sleeve bores would you need?
Offline Powderman
« Reply #10 on: June 18, 2013, 10:51:19 AM »
I got Cometic Gaskets to make them for me for $25 for the pair, much cheaper than I thought it would be.
They make the gaskets anyways so all they need is to pull up the program and change the bore to 3.445" and blast them out. They may sponsor them to me, waiting to hear back. Thanks for your help guys. Hopefully this is the last setback on this motor and we can move forward to making noise with it soon. Ohio here I come.
« Last Edit: June 18, 2013, 10:55:15 AM by Powderman »
« Reply #11 on: June 18, 2013, 02:37:24 PM »
Thats one sporty I want hear or see running..
Offline Powderman
« Reply #12 on: June 19, 2013, 09:07:13 PM »
Believe me there is nothing I would rather do than post a video here of this thing making noise. It'll be the first time since this motor was built 36 years ago. Life and responsibilities got in the way of completing it. Now nothing will stop me from finishing. I'm turning 60 in a few weeks and it time to get it finished before it's too late.
  • Moderator
« Reply #13 on: June 20, 2013, 12:45:19 AM »
Frank,
Powderman,
George
George, if you want to move it to the race forum, It's quite simple.
Only a Mod or the thread starter can move threads.
You will find the option at the bottom of your page as you were the thread starter.
Sam. ;)
